Question about SkyGolf SkyCaddie SG2 GPS Receiver
My skycaddie was immersed in water. Battery shorted. will not recharge. unit dried. Do I just need a new battery?
    Sergeant:
  • 170 Answers
If the device got wet while the power was on` it most likely shorted out components in the device and you will need a new one. if its worth your time and money you can try purchasing a new battery, but chances are the device still has water inside and is shorting it still. dis assembly and inspection of inside cavity is the only way to guarantee that it really is DRY completely, but is illogical to try to take these devices apart ~ electronics dropped in water have to pretty much be called defective after immersed.
sorry .thats probably the wrong answer. but its 100% truth
Posted on Jul 31, 2010
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Battery icon doesn't change
Hello :
Simply your battery is dead [ can't be recharged anymore ] and needs to be replaced .
Batteries have lifetime . At the end of this lifetime the battery can not be recharged anymore . There are chemicals in the battery that become inactive anymore . In this situation there will be no other solution than replacing the battery with new one .
please rate !
Apr 16, 2010 | SkyGolf SkyCaddie Handheld GPS Unit
It fell in water and wont turn on or charge
As you will appreciate - water and electronics do not mix. The soaking in the water will have caused a short to occur somewhere on the circuit board or other components.
One key to saving soaked electronics is speed and the ability to rapidly remove the battery to prevent power being supplied to the short. The battery in this unit is pre-installed and is not removable so unfortunately it is highly likely that the unit will be beyond repair I am afraid.
However, sometimes you can be lucky. If the unit was not too badly immersed in water, there is a possibility it will work again if it is left to dry out in a warm area of the room.
Do not use hairdryers or heat of any form as this will make the problem worse not better. Using warm sunlight in a window or left in the vicinity of a radiator (but not on the radiator) - gentle warmth is the best approach.
You should wait 2 or 3 days with it drying out in this manner before you try powering up or charging it again. If a fatal short has not occurred this approach can sometimes work but unfortunately there is no guarantee.
Hope this information helps. Thanks for using FixYa.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
My gps fell into water by mistake, any way to fix it, its not showing up anything accept welcoming screen and then it turns off automatically. any way to fix?
Yes, most likely you can restore your unit by placing it in a large jar with dry rice. The rice will draw the moisture out of your unit and it will most likely start working again. This works witrh cell phones also.
Dec 17, 2009 | Garmin nuvi 250W GPS Receiver
My phone has been damaged by water. it is off and on
The first thing happens when a phone is immersed on water is the battery gets shorted draining its charge. The battery should be removed immediately and let the phone dry completely. Place it near packs of silica gel and let it dry for at least a day or place it in a place with an installed dehumidifier. Make sure the battery is not damaged before inserting it into the phone. It is recommended to use a known good battery.
If the problem still exist after the phone is dried and the battery is good, have it checked by a qualified technician. Oxidation may have took place affecting the circuits and must be cleaned properly. You can ask the technician for just a cleaning service of the board and blow it dry including the entire assembly to remove any moist.
Dec 01, 2009 | Samsung SGH-E740 Smartphone
Dropped phone in a bowl of liquid
REMOVE THE BATTERY!
*Choice one- Methyl Alcohol
Clean the circuit with Methyl Alcohol
  • Dip a q-tip in the alcohol and squeeze the q-tip.(you want it to be almost dry)
  • Very carefully clean the circuit and allow it to dry, it is important that you clean around the medal to prevent short circuits.
*Choice two- Rubbing Alcohol
Clean the circuit with Rubbing Alcohol
  • Rubbing alcohol has a slower evaporation rate so you need to wipe the area with a clean q-tip after cleaning it with the alcohol.
If this dose not work you need a new phone, good luck.
Aug 15, 2009 | Motorola Mobility RAZR V3
Unit taking long time to establish satellite connection?
5-7 mins is not unusual in many cases. Battery condition has a lot to do with the time it takes to establish connection. Recharge or replkace batteries with better quality ones and keep well charged up if you use rechargeable ones
Jul 23, 2009 | SkyGolf SkyCaddie SG2 GPS Receiver
Won't recharge, won't reset
soak unit it rubbing alcohol if dropped in water(water has deposits when dry that short stuuf out alcohol cleans and leaves no residue)let soak for a few hours(make sure battery is out)then shake out excess alcohol and let dry for a day in warm dry area.clean contacts on battery with alcohol ans qtips and reinstall battery then try to charge-same thing happened to me tried this and worked fine hopefully didnt short chips!!!!!Best of Luck to you!!!use 90% rubbing alcohol!!!let me know if worked!!!
Jun 30, 2009 | Sony Walkman NW-A808 MP3 Player
My Camera in water
Usually when cameras fall in water, the circults gets wet and mostly causes a short-circuit which causes the components to fail. If the camera fell in water without the battery you could try
1. Drying it completly before putting on the battery to test it.
2. Immerse the camera in alchol complety. It basically substitutes water (removes moisture) and vaporises quickly. Dry it completly and test it with battery.
If the battery was in when you dropped it your chances are less. You could dry it completly and show it to a technician ASAP. Make sure no moisture reaches it.
Hope its still under warranty.
Oct 22, 2008 | Pentax *ist DS Digital Camera
Skycaddie : cannot plug it in to recharge
Had problems charging mine, bought replacement battery and it wouldn't charge either. Looked inside charging port and noticed a slightly bent pin, straightened it and works perfectly. Bought battery from batterybob.com $26 vs $49 from skygolf.
Jun 21, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
SkyGolf SkyCaddie SG2 GPS Receiver Logo
232 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Marvin
Marvin
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
