Question about Zanussi 24 in. LS6E Free-standing Dishwasher
Zanussi LS6 undercounter dishwasher showing a C3 error. Any ideas?
  • 159 Answers
SOURCE: Dishwasher
If you coud describe where you hear the noise that would be helpfull. the noise could be somethig hilling one of the spray arms or something stuck in the pump impeller. if you only wear it when it is only in a wash cycle I would say it may be someting in the wash pump. But also make sure the spray arms are moving freely
Posted on Jul 19, 2007
  • 10 Answers
SOURCE: Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Posted on Dec 15, 2008
SOURCE: Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Posted on Sep 06, 2009
  • 93 Answers
SOURCE: Convert a whirlpool portable dishwasher to undercounter
I would simply slide the unit under the counter and connect the inlet and drian hose permenantly.If the unit is not tall enough and sits too low then build a shelf or false floor in the cupboard for it to stand on.
Posted on Dec 30, 2009
SOURCE: Zanussi ZSF 6161 Dishwasher error codes
Hi ya, Zanussi dishwasher zsf 6161 error i30. I tilted it back, mopped up. Used dishwasher cleaners, cleaned around door, filters but it happened again. Any ideas?
Posted on Aug 13, 2010
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
Zanussi dishwasher showing e2 error what's wrong in machine
E2 - Tank temperature low
Does the tank heating element work properly?
Are the connectors correctly connected?
Are the dishwasher feed voltage and current correct?
Is the relay RL5 on the board disconnected or faulty?
Dado
Apr 14, 2015 | Zanussi Dishwashers
Zanussi dishwasher beeps once and end of cycle light flashes
Most likely your dishwasher finds fault.
Appliances without a display will show the alarms by a number of flashes of the LED "end of cycle".
For example: one flash = i10, two flashes = i20
..........and so on
So, count how many times LED "end of cycle" flashes and you will know the error code.
Dado
Aug 24, 2014 | Zanussi Dishwashers
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
Mar 22, 2008 | Dishwashers
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
GE Profile dishwasher GSD4930X88WW will not start C3 error code
The wiring diagram for GE dishwashers is usually found under the dishwasher, take the bottom panel off, then look for a envelope about 3"x5" up against the bottom side of the floor of the dishwasher, right under/behind the front edge. If its not there it makes servicing it tougher. C3 code means the drain sensor is not functioning, C7 code means the temperature sensor is not functioning.
As to the voltages used, I would only know that by looking at the wiring diagram (which I do not have).
Jan 14, 2008 | GE GSD3800G - Multiple Color Built-in...
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Zanussi 24 in. LS6E Free-standing Dishwasher Logo
418 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
