Question about Kenmore Microwave Ovens
I have a Kenmore Microwave Oven Model No. 363.62709300 and it stopped working. On the screen of the oven appears F3. Can you tell me what this means and how I can get my oven to work?
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: F3 meaning ?
"F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds"
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 12, 2009
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
Have a TE code showing on my kenmore elite microwave hood combo
At some place I saw that the TE error refers to the touch panel.
If you go to http://www.searspartsdirect.com/ and enter your full model number you can get parts list and buy parts and even get repair advice.
Link below shows how to replace a control panel on some model of microwave oven. In the video you will see a ribbon cable being removed. You might want to wipe the contacts of the ribbon with alcohol and put it back in to see if it helps with your problem.
F3 error Microwave oven control panel replacement
Sep 11, 2014 | Kenmore Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Twice my new kenmore microwave has just started beeping with the error code E11 appearing on the screen.Have to unplug it to stop it. WHat is going on?
I think this microwave oven uses an inverter to control the power output of the magnetron. Usually the microwave will advertise this feature with a trade name like "accu-wave" or "true-power" or some similar label on the front of the microwave. Assuming that is the case here, then the E11 error means a bad inverter
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 07, 2014 | Kenmore Microwave Ovens
F3 code
An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
On many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Aug 10, 2011 | General Electric Microwave Oven
Error message of "F3" appears
F3 or F4
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Keep us updated.
Jul 10, 2011 | Hotpoint RVM1325WW Microwave Oven
Kenmore microwave oven model # 721 63684300 built 5/2003. Does not heat, after 25-30 sec. F9 appears on keypad. Everything else works---timer, clock, lights, horizontal turnstyle.
I checked the owners manual and it does not list the fault codes. Manufactures leave this information out of the manual most of the time so you have to call them for service.
Call 1-800-4-my-home (sears) and tell them the problem. You will also need to provide the m# so have that ready when you call.
Good Luck
Dec 20, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
What the code f3 mean my stove model # is 911.9584991
This model ( Kenmore ) has been built by Roper ( 911 - First 3 digits tell you the manufacturer's name ).
F3 refers to Oven temperature sensor open.
You need to check the oven temperature sensor.The value of oven temperature sensor should be around 1100 ohms at room temperature. In case, it is too high or low, you need to replace that.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2010 | Kenmore Microwave Ovens
Microwave Ovens Logo
99 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
