Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My refrigerator doesnt make any ice anymore? - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
    Sergeant:
  • 170 Answers
Look in your manual for the location of the water filter.
buy a new filter. if it has no filter , the only other problem is the water line is dirty and water cannot get to the icemaker. if the machine has water at the dispenser and you still have no ice , then your icemaker has a problem
Posted on Jul 31, 2010
My whirlpool side by side is not making ice and im wondering if the sound it usually makes, like water filling up, doesnt happen anymore have anything to do with it???
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Nov 01, 2011 | Refrigerators
My side by side wont make ice and it usually makes a sound like water filling something but doesnt anymore should i replace the valve part that regulates water or the ice make part???
yes its indicating towards faulty water valve.
The ice maker is not making ice, it makes the first set of ice but keeps it there and it doesnt make anymore,what can nit be?
1 keep the shut arm down position
2 check the water filter , water filter replace every 10 m
if water filter ok. check water valve
good lock
Jan 12, 2011 | LG LFX21960 Stainless Steel Bottom Freezer...
Ice maker doesnt work anymore
the cause may be several things like bad water valve . no air flow over ice mker cause is no fan in freezer . tempt in freezer is abofe 15 deg . / some times cleaning the coils under neath and make sure the fan down under is going also. . and if all else failes the ice maker may be bad . hope some of thes will help .. ****
Feb 23, 2010 | Refrigerators
LG LSC27931st.ice dispenser flap doesnt close after ice drops
Not that this is much help, but I have the same problem with the same model.
Dec 02, 2009 | LG LSC27931S Side by Side Refrigerator
My rangemaster fridge is not dispensing ice anymore what should i do to fix it, when i press the botton it doesnt come out
Try lifting the bar that moves on ice box. If moving this bar has no affect on the machine turning on and off, then the circuit that is attached to it is faulty. You can get manual and parts at repairclinic.com
Sep 23, 2009 | Refrigerators
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Icemaker problem
check that flap or check and see if freezer light stays on
Mar 31, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
After my mini fridge was left open over night, it doesnt get cold anymore....
Being left open can let lots of moisture in that can freeze up the air circulation paths. First thing is to leave it off and unplugged for a couple days to melt any hidden ice build up from being open all night. Then start it up like normal and see if it works properly. If not then repost and we'll go from there.
Jan 09, 2007 | Haier HSB03 Compact Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
137 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
