Question about Homeland Security Cameras Home Security
How much is a homeland 2 channel automatic switcher monitor with audio/video camera cost ?
4 Suggested Answers
SOURCE: 4-wire surveillance camera wiring diagram
need to know what wires do what on security camera ive bought at car boot wires are 2 black 1 yellow 1white 1red would make my day if you have an answer thanks
Posted on Apr 08, 2011
So I have a 4-wire video doorbell. A bit old. According to the back of the doorbell unit, the four wires are V-Out (assume video out), A-Out (assume audio out), +B (assume Button), and -GND (assume ground). The camera and the infra-red LEDs need power when the video is switched on. The unit supports two-way audio and so there is a speaker and microphone in the unit. The microphone would obviously use the A-Out and Gnd, the camera the V-Out and Gnd, and so I assume the +B provides power to the camera, and LEDs (except when the button is pressed?). A small red led is always on, suggesting power is always available along the +B and -GND to power that.
I assume also that the "receiver" works by sensing the button is pressed (a different resistance in the circuit?) and then it switches on the video display and allows the microphone to on the unit to be heard at the receiver for the 180 seconds that it stays on.
Given the instructions and the limited wires and analogue simplicity, I would say the unit always draws 14W because the camera and microphone and the LEDs are always on and transmitting.
I just don't know how the audio signal is transferred back to the speaker...
On my unit, the green wire is V-Out, yellow is A-Out, red is +B and brown is -GND.
Posted on May 15, 2011
Cut wires Blue whight yellow orange wires go to what on a security camera
Posted on May 16, 2012
X pose 4 ch h 264 dvr not working
Depends on how much wire you have left to work with?
Aug 16, 2014 | Homeland Security Cameras Homeland...
Tip
Kramer VS4x4ycyl Manual Download
Download Kramer VS4x4ycyl Video Audio Matrix Switcher Manual
Have you misplaced your Kramer VS4x4ycyl Video Audio Matrix Switcher Owners Manual?
Would you like a digital, searchable, pdf version of the VS4x4ycyl Video Audio Matrix Switcher User Guide?
Follow this link (& click FREE) to download a pdf version of the VS4x4ycyl Video Audio Matrix Switcher installation instructions.
I hope that helps.
_______________________________________________
on May 09, 2010 | Audio Players & Recorders
I have a Kramer VP729 video/audio switcher stop getting signal from hdmi 1 and 2 inputs. I have checked HDMI cables they are working. I have turned off receiver reset it to factory settings and reprogram...
The 729 is a pretty old box and only accepts HDMI @ 1080i 1080p. 720i 720p 480i and 480p
Because the 729 is HDMI compliant, and HDCP compliant, you cannot display an HDMI signal on a computer monitor which will not display a content protected source.
Connect your source directly to the display, if that’s ok then try through the switcher.
Check for the latest firmware from Kramer,
You can always call their tech support team.
Nov 24, 2017 | Kramer ProScale VP729 Videoaudio switch ...
We would like to buy the Edirol V8 video switcher for live internet broadcast. I need to know if this is the correct product for us. We have 3 cameras and a projector going into the switcher and then it...
Dear crane_editor,
For broadcasting the video signal coming from the V-8 over the internet you need to have a computer that is equipped with a composite or S-Video input card. Additionally you might need an audio input as well with the possibility to delay the audio to have a live stream with lipsync audio and video.
Roland has launched a new product recently which is actually designed for live streaming applicatons like this. It's called VR-5 AV Mixer & Recorder. This device has a USB streaming output for easy connecting with a computer. The computer will recognize the VR-5 as a USB audio/video class device (like a webcam) so your setup is ready in minutes.
Further the VR-5 is equipped with an audio mixer (with delay for lip sync), built-in preview screens with touch select, PC VGA input, media player and AV recorder (SD card).
Probably the VR-5 covers all of your needs, without the hassle of difficult configuration of all kinds of separate devices.
Kind regards,
Kees
Sep 22, 2011 | Edirol / Roland V-8 Eight Channel Live...
My TX-SR605 has two HDMI In slots. I want to add a third HDMI device - a ROKU box. Please advise how best to do this. Thanks.
Use an HDMI switcher like this. Then you can select any of the three inputs and run it to the receiver. Simply leave the receiver on that input and use the switcher for source selection.
May 28, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
I need the user manual for Homeland Security Camera Model 01880
i have a homeland security camera with monitor , a philps tv and a jvc vcr .. how do I hook up monitor to view and record off tv
Sep 03, 2009 | Home Security
Audi switcher : out
HI,
1.click Start -> Run … enter:services.msc
2. Click OK, a services window will appear, scroll to windows Audio, double click
3. Windows Audio Properties will appear. Change startup type to “Automatic
4. First click Apply, then click on start to start the service
Does it solve your issue?
Aug 27, 2009 | Computers & Internet
How do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
Mar 17, 2009 | Canon XL2 Mini DV Digital Camcorder
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Sound from digital input(s cut out
You are probably correct. The input switcher IC or the power supply feeding the Optical switcher is most likly got a problem. The cost to diagnoise a problem like this could cost you with a repair, more then you could most likly get a new reciver for. Its a shame of all the great technology that gets thrown aweay in the dumps every day. Good Luck PS please do not forget to rate this thread.
Dec 11, 2006 | Kenwood VR-2090 Receiver
Home Security Logo
80 people viewed this question
Top Homeland Security Cameras Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Homeland Security Cameras Home Security Expert? Answer questions, earn points and help others
