Question about Bosch HBN 9061 / HBN 9021 Double Oven
The glas bulb cover at the top of the grill/top oven has broken leaving the glass edge stuck in the thread. I have a replacement but cannot get the old remnants out. Do I have to call an engineer to dismantle it or is there an easier solution?
  • Bosch Master
  • 2,005 Answers
Take a wooden stick about the same diameter as the broken bulb; place a washchoth over the end; push the stick into the bulb base in the oven and, turn the stick counter clockwise until it comes out. the stick is an insulator so you won't get shocked and, the cloth grips the bulb base.
Posted on Jul 31, 2010
  • Jim Goldsmith
    Jim Goldsmith Jul 31, 2010
    a potato will also work; so, says my wife...
  • sue_garnett
    sue_garnett Feb 13, 2013
    After the lens cover broke away leaving just the rim in the fitting I've managed to remove the remaining glass rim by (after turning the power off and removing the bulb) covering a large potato with a slightly damp dishcloth and pressing it fairly firmly up into the fitting and turning anti-clockwise. Worked a charm, thank you!
Any suggestions on how to remove covers on lights in Ilve oven so I can replace globes? Tried warming oven as suggested but they wont budge. Is the only solution to get an Ilve technician?
when you go to the service agent to get the correct bulbs ( (need to be pyrex glass ones as normal bulbs will not stand the oven heat) ,ask them how to remove
the fat from cooking gets in the glass threads and then goes to carbon , making it very hard to turn the covers
maybe a oven cleaner sprayed around the glass may help release the threads
Jan 14, 2018 | Ovens
The thread part of the oven light bulb is stuck. How can I remove it?
uNPLUG FROM POWER. WITH A SMALLISH, NARROW STRAIGHT SCREWDRIVER, ATTEMPT TO GET THE TIP BETWEEN THE BULB SCREW AND THE BOLDER AND ,GENTLY BUT FIRMLY ATTEMPT TO BEND THE SIDES OF THE BULB SCREW TOWARDS THE MIDDLE.WHEN A FEW BITS OF IT ARE DEFORMED THAT MAY ALLOW YOU TO UNSCREW IT.BE CAREFUL NOT TO APPLY TOO MUCH FORCE,YOU DO NOT WANT TO DAMAGE THE SOCKET OR SNAP IT OFF.
I have assumed that the glass part of the bulb has snapped off?
GOOD LUCK WITH THIS
Jun 14, 2015 | Neff Ovens
Change light bulb smeg oven
The glass bulb probably is a bayonet or screw fitting.
Nov 25, 2017 | Ovens
I have a Bosch HBN double oven unit. The bulb in the lower oven has broken with the screw-in base of the bulb stuck. The glass top of the bulb has come away. Cannot get the remaining bit unscrewed due to...
If you try using a thin NOSE PLIER - with a n ALIGATOR MOUTH- it will be easy to pull out by unscrewing the stuck up damaged thread of the bulb. Once it i s free even with a higly pointed screwdriver it can be pushed to unscrew.
Please try this out and it will be easy to replace.
Aug 19, 2011 | Bosch Ovens
Hi I have a stoves 720EF oven and grill, and the light bulbs need replacing. the instructions are not clear enough! It says to grasp the back edge of the light cover and move forward. There aren't any...
As you have found out the covers are made of glass and can get very hot, so don't attempt this if the oven has been on for even a little while. You may not have noticed it but in the centre of the edge of the glass cover facing you when you look in the oven, there is a small recess in the glass adjacent to the oven wall. It is probably covered up by grease etc. It is in the centre about 1cm long and about 3mm deep. You will need a screwdriver ( an old blunt one is best so there is no sharp edges) that just fits into the recess length wise and then twist it. This should start to prise the cover away from the oven wall and then you can get your fingers behind it to pull it away. Note the cut out on the edge of the glas when refitting. This is to allow for the lamp holder. When you put it back, as long as the recess is towards the font of the oven, you should be ok.
Jan 02, 2011 | Stoves 720EF Electric Double Oven
I have a siemens electric oven. The bulb has blown and is encased in a glass cover. The intructions say to turn anti-clockwise to remove the cover, but it just won't budge. Ant ideas how I may free it?
The bulb cover is probably gummed up with solidified oven grease and therefore stuck.
The only thing you can try is to turn the power off and spray around the edge of the glass with oven cleaner and leave for a couple of hours in the hope that it will soften and allow you to unscrew it.
Be careful not to get the spray cleaner on to the heating elements.
Dec 17, 2010 | Ovens
Can't get the light out to replace it?
You have to use a blunt bladed screwdriver to prize the edge of the glass cover away from the oven side. You should see a small cutout in the middle of the edge of the glass that is facing you, to put the screwdriver in. When replacing the glass cover, there is depression in the glass to allow for the bulb. Ensure you put the lense back the correct way.
Jul 31, 2010 | Stoves 720EF Electric Double Oven
How do I change the bulb in an Inglis oven. Can't
Normally the cover will have an anticlockwise turn thread. Twist the glass cover anti clockwise and it should unscrew.
Jan 04, 2010 | Ovens
Outer glas of the dor broken its a QA make built
I will give you summary instructions on how to repair the door outer glass on a built in kitchen.
Prepare a space on a table, where to work on the door. Cover the taple with newspaper.
Remove the door. On some model you may just need to lift and pull, on others you need to free the hinges, usually undoing few screws.
Put the door on the table. Remove fragments of splintered glass if the glass is falling apart, otherwise leave it all in one piece.
On the table remove the set of screws that are holding the external frame and glass.
Remove external glass and replace it. You can use pliers and a cloth if needed.
Do operations in revers order to refit new glass.
You can find parts here:
Appliance Parts -Research, Repair & Replace.
Oct 14, 2009 | Ovens
Broken screw of Light bulb stuck in Neff Oven
hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Jun 29, 2009 | Neff B1421 Electric Single Oven
Bosch HBN 9061 / HBN 9021 Double Oven Logo
312 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
