Question about Morphy Richards 42298 Iron with Auto Shutoff
No steam from iron
I have a 42270 steam generator iron, although everything gets very hot in both the iron and the boiler unit the iron will not produce steam.
I have found out from the missus that she hasn't shanged the filter in 18 month's !!!, I have changed the filter but still no steam.
Is this a fix I can do myself
HELP
2 Suggested Answers
vko007us
  • 254 Answers
SOURCE: generator iron gets warm only
PLZ SPECIFY THE BRAND & MODEL NO OF THE PRODUCT TO SPECIFY UR ANSWER
Posted on Aug 16, 2011
My Rowenta dg5030 is not producing steam. The iron plate gets hot and the boiler is hot. Just when you depress the steam button, nothing comes out. There is steam in the boiler. Thank you
The small transfer water-line to the steamer section has closed up. This is due to contamination of salts, accumulated calcium or other debris. Its baked on and not easy to remove. All I can tell you is: always use filtered water or distilled water in the NEW IRON that will replace this one.
Feb 11, 2018 | Rowenta Irons
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
Hi guys. I have a Hoover ironspeed IS21-1 steam generator iron. I love this iron it's the best steam generator I've ever had but now once it's heated up and I go to use it as soon as I press the button...
Try unplugging everything that is using that circuit because it's possible that you have too many items plugged up. Also try other outlet.
Jan 14, 2015 | Irons
How do I get the boiler on my rowenta steam generator to fill? I was given this model.
You should only use distiller water in the steamer. Never ever use tap water! This is what caused lime and scale build up.
Since it's to late, you have nothing to loose by trying this to descale the unit:
Put up to one cup of white vinegar into the reservoir. Fill 3/4 of the way with water. Turn unit on and let it heat up, but DO NOT RUN STEAM THROUGH THE LINE. Once heated up, turn unit off and let it set for hours. Drain and rinse well. Then run a water only batch through the steam cycle. There are companies that sell special de scaling solutions. But hopefully, the vinegar will work.
Apr 25, 2014 | Rowenta Steam Generator DG050 Iron
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
Users instructions elitech 2000w steam iron
alas we've had the same problem since day one, just opened it up, must be the boiler unit leaking at the start to emit the steam so the handle gets hot and now the seal is totally gone it will just leak when the water gets too hot
Dec 12, 2011 | Irons
My Rowenta Master Steam Generator - Steam button turns on but does not turn red or heat.
- First the good news, the service center in Concord is very good and would you believe they have new in the box Rowenta DG980 in stock!
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Now the not so good news. This model uses what I call a "flutter pump" that turns on when the boiler needs more water pumped in if the reservoir is dry and the red light comes on indicating it is out of water.
Generally, if you remove the blue water reservoir and turn on the unit, in about 5 minutes the boiler should have sufficient heat converting the residual water in the system to steam, for at least one or 2 "bursts of steam".
If all this works, then likely the $75 electronic printed ckt board driver detector is okay. It enables the flutter pump, fills the boiler with a few tablespoons of water to be converted to steam and repressurizes the steam system. It is the sequence logic this board does that you can use to determine the bad part, find and replace it yourself. There are many thermostats and sensors and without a schematic it is tough to reverse engineer.
The most expensive parts are the tank heater and sole plate elements followed by the ckt board (make sure you label all the connections & draw a color coded diagram before replacing this part) especially likely if the flutter pump does not turn on and everything else gets hot & steams is okay if unit less than 5-10 yrs old. BTW a new unit is $350 so you have to weigh your options and talk estimate for repair with repair tech if you go that route. A lot can be said if your unit is not that old, have used clear water, allowed steam to run dry (minimizing long term storage with water in unit), and cleaning the boiler as specified in manual. It is worth the price to repair OR replace. It is a great machine.
May 16, 2010 | Rowenta DG-980 Iron
Euro-Pro Steam Generator G6200H iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
May 18, 2008 | Euro-Pro Steam Generator EP8001 Iron
I have a Rowenta DG-980 steam generator. It spits little grains of something when I use my iron. It doesn't hurt my clothing, but I have to brush the stuff off my clothes when I am finished ironing them. I...
Hi, Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
May 06, 2008 | Rowenta DG-980 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Morphy Richards 42298 Iron with Auto Shutoff Logo
46 people viewed this question
Top Morphy Richards Irons Experts
Mack Baxter
ray gallant
Are you a Morphy Richards Iron Expert? Answer questions, earn points and help others
