Question about Maytag Neptune MDE7500AY Electric Dryer
I have a Maytag Neptune MDE7500 electric dryer with an LCD touch display. When I open the dryer door the display works and turns on but If I set it to dry on any setting and press start I close the door and nothing happens. The display shuts off and the dryer doesn't start. The LCD won't turn on or function again unless I open the dryer door again. Please let me know what is causing this and if there is anything I can do to fix it myself or do I have to call for service. Thanks.
SOURCE: Gas dryer does not dry clothes
try replacing the solenoids/coils.
Posted on Jan 10, 2008
SOURCE: Maytag Electric Dryer - Control panel doesn't light unless door is open
I fixed my own problem...I took the extra 4th wire(green) and attached it to the dryer body...There is a screw with the word ground stamped into the metal above it. This is right next to the panal where the cord goes into. I just unscrewed it and put my cable there and the dryer works perfect.....These things need to have a detailed diagram on the dryer....
Posted on Feb 15, 2009
Maytag317
  • 1136 Answers
SOURCE: Maytag Neptune Dryer sometimes dries sometimes not?
Hi, Have you checked the venting that goes outside. Most of the time, this helps especialy because it is electric dryer.
If I can help further, please let me know. Thanks
Vic
Posted on May 11, 2009
protek480
  • 1723 Answers
SOURCE: How do you remove the bottom cabinet of a Maytag Neptune Dryer
OR..... you could watch the video...
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 07, 2009
  • 530 Answers
SOURCE: Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Posted on Aug 19, 2009
Maytag Neptune dryer displays 88 and won't start
our dryer just keeps running and doesnt not shut off after cycle is done. You have to unplug or open door for it to shut off. This is not a refurbished dryer we had bought brand new
Dec 30, 2013 | Maytag MDE2400AYW Neptune Electric Dryer
Hello all, My MDE7500AYW Maytag Neptune Dryer was working today and just quit. It is plugged in and the drum light works when the door is open, close the door and nothing. No LCD display, no...
looking at schematics looks like you main control board is the faulty part. you have done a very good job of tracing the voltages from the source. been that all voltages are present and door switch is good the part left is the control board. here is the part# 33002886. you can find it at sears website or service center.
good luck to you.
Feb 15, 2011 | Maytag Neptune MDE7500AY Electric Dryer
Maytag Neptune shows power but wont function
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag neptune dryer. When I open the
Issue:
I have a maytag neptune dryer. When I open the door it doesn't turn on . What could be the problem?
Solution:
This is normal! The dryer has a door switch that will prevent it from operating with the door in the open position. This is a safety feature and cannot be overidden.
Aug 13, 2009 | Maytag Dryers
Maytag Neptune dryer won't start/
I do not have that specific dryer but try these simple steps.
Maybe they will help you.
1. Shut the electric breaker off to the dryer for about 30 seconds and and back on.
2. Open the dryer door and inspect the switch that tells the dryer the door is closed. work it by hand just to make sure it is not stuck.
3. Spin the timer controls to another setting and see if the other setting will work.
That's all I've got for now...
May 20, 2009 | Maytag Neptune MDE6700A Electric Dryer
Can't figure out how to get the top off
http://www.pcappliancerepair.com/model-display.php This one looks like a real puzzle. Open the door and look for screws holding the front on, the top seems to lift up once something is released.
Apr 26, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer door will not open
only the washer has a main bearing. the dryer only has bearings in the motor and still would not cost 1,000 to fix. did you door issue get fixed? Joe
Nov 13, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Maytag Neptune MDE7500AY Electric Dryer Logo
115 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
