Question about Sharp AL-1530CS All-In-One Laser Printer
DRIVER SHARP AL1530CS - Sharp AL-1530CS All-In-One Laser Printer
    Scholar:
  • 126 Answers
Available here for free download-
http://download.cnet.com/SHARP-AL-1530CS/3000-2116_4-70411.html
Posted on Jul 31, 2010
Tip
Sharp AL Series Copier L1 L-1 Error Code Cause and Solution
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H3 H-3 code reset procedure
To reset the H3 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This works on the following models:
My Sharp AL1530CS Copier is sick. I have a Sharp AL1530CS Copier. It has been great but has gotten sick. I replaced the AL110TD cartridge recently with a generic cartridge and toner leaked from it
Your machine is jamming (flashing p) because the toner that spilled has made the rollers slippery and they cant pull the paper out of the paper tray.
Apr 07, 2017 | Sharp Office Equipment & Supplies
Tip
Sharp AL Series Copier L3 L 3 code meaning and solution
Good Luck and thank you for using Fixya
on Mar 16, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier H4 H-4 service code reset
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
on Jan 04, 2010 | Office Equipment & Supplies
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Aug 21, 2009 | Sharp AL-1217 Copier
Sharp AL1530CS software
Be sure to unplug the usb connector before installing the driver
Mar 31, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Open Questions:
Sharp AL-1530CS All-In-One Laser Printer Logo
627 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
