Question about Ingersoll Rand SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow
Wont turn over
I pull start it wont turn over compressor is new has 20 hour only
  • 50 Answers
Did u check oil level in pump end take belt off and try 2 turn pulley iff no go pump is seized pull off head and see iff ring is broke
Posted on Aug 02, 2010
We have a Kenmore 16, model model 253.8283680, that recently continuously cycles on and off. What could be the problem associated with this?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The normal cycle is: Your compressor will turn on to raise the freezer temperature 20 degrees F. above the set temperature, and then the compressor will shut off, Until the freezer temperature drops 20 degrees F. below the set temperature and again the compressor will turn on.
One of the main problems with this type of freezer is the door gasket becomes crushed over time or the door is so thin it becomes deformed.
Do not try to replace the door gasket. You have to soak the new gasket in hot water for 1/2 hour and then form it on the door.
If you notice a gap in the corner of the door - pull hard on it to get it flush.
Recondition the door gasket - With a hair dryer and a kitchen spatula, heat the gasket and try to expand the gasket by pulling out with the spatula.
You can purchase a special freezer lubricant. Be sure not to over do it. It can make the door hard to open. P/N 542638
1/2 Oz. $12.00.
Mar 19, 2015 | Kenmore Freezers
08 yz250f wont start after sitting up
turn gas on under tank ,get new spark plug, gas mite be bad.
Feb 15, 2014 | 2004 Yamaha YZ 250 F
My compressor is not turning on the fan is going but the compressor wont kick on what could be wrong it was working fine just an hour ago
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor using a device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new compressor.
Jun 20, 2011 | Goodman CKL36AR36 Air Conditioner
Compressor running non-stop
Temperature setting/changes takes more than 2 hours to stabilize.If still running non stop after 24 hours use a digital thermometer to check the internal temp of refrigerator. If not cold enough it will not open the thermometer and turn off the compressor. Meanwhile, a 20 minute defrost cycle is about right.
Sep 23, 2017 | Amana ARB220ZCS Bottom Freezer...
Compresser wont start
Buy you one of those starting capacitor and load protection assembly. Available in your local ac supply. They are easy to install and reasonably cheap( about 20 bucks or less). The compressor should start. We use them when installing new compressor of if the compressor wont kick in. They work almost all the time.
Mar 06, 2010 | Samsung RM255LASH Side by Side...
Motor tried to start but couldn't, was using long
I'm assuming that your on/off is a lever or switch built into the pressure switch. If so, the pressure switch sounds like the problem.
Nov 14, 2009 | Air Tools & Compressors
Red ring of death on my console
turn it off pull it open and pull the fan out for 20 minutes but turn it back on before you start counting after 20 minutes is over plug the fan back in and wait half an hour then it should be fine but if its 4 red lights buy a new av cable
Apr 07, 2009 | Microsoft Xbox 360 Elite Console
Temp is rising
First Check the voltage to the compressor. Usually just 2 wires. If you do not have voltage and you are sure it should be running (it is turned on and plugged in) Check the controller (thermostat or Sensor/board assembly) because your problem is not with the compressor as of yet.
Assuming you have power to the compressor and the fan motor there is running up to speed the coils under neath are clean here are the items to look for to check out your compressor:
Getting to this step: Either your compressor is broken inside or the start components are not working properly. Ohm the compressor terminals to ground and across to each other.
If any read anything to ground the compressor is bad.
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
Assuming the above checks out: Get a new Start relay (start capacitor if so equipped) relay and overload (and capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Jan 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Wont cool or freeze
Could it be the compressor not running?
If you suspect the compressor try to follow this to decide your next step:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These little helps allow you to get the compressor running or decide that it needs replacing. To Decide if Either your compressor is broken inside or the start components are not working properly.
1 Ohm the compressor terminals to ground and across to each other.
After 3 or 4 trys if the results dont addup the compressor motor is bad. Replacement is required. Is this machine worth a new compressor? Is it still under warranty? Is the labor and all parts covered?
2 Assuming the above checks out:
Jan 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge not staying cold
did you let the fridge stay in it's new place for 24 hours up right before turning it on?
Try turning it off for at least 24 hours and start it back up again.
If you moved it on its side the compressor oil flows into the lines and must beable to drain back down before using it.
If not you'll seeze the compressor.
not good.
Jun 25, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ingersoll Rand  SS3J5.5GH Wb Ir Portable Air Compressor 5.5HP Honda Gasoline Engine Single Stage 8 Gal Twin k Wheelbarrow  Logo
211 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
