Question about Phonic Helix18fw 18 Channel Mixer with Firewire
Trying to get my phonic helixboard 12 mk II to link up too my vista laptop via firewire
  • Phonic Master
  • 5,603 Answers
Here is the system requirements cut and pasted from manual:
• Microsoft�������������������������®Windows®XP������������SP1 and SP2
• Available FireWire port
• Intel Pentium������������������������������������������������®4 processor or equivalent AMD Athlon processor
• Motherboard with Intel or VIA chipset 5400 RPM or faster hard disk drive (7200 RPM or faster with 8 MB cache recommended)
• 256 MB or more of RAM (512 MB recommended)
You will note that Vista is NOT listed. Best thing is to backstep your laptop to XP operating system.
Posted on Aug 01, 2010
Operations manual
Here is a link to your manual, hope it helps.
http://www.phonic.com/en/helix-board-18-firewire-mkii.html
Nov 27, 2013 | Phonic Helix18fw 18 Channel Mixer with...
My power supply in my phonic helix mkII 24 board is blown, it was messed up in a power surge, I have tested the remaining connecting parts and everything else is fine. I contacted phonic and they dont...
Usually it's the electrolytic caps that go in those, they basically "cook" and dry out, a power spike just pushes them over the edge. I've also had this problem with mine & 2 12 volt switchers for my HD and for the satellite had the same fix. I added a fan which helps. Another solution is to go to a second hand store, find 3 power suplies (15v,15v, 5V) and put them in place of the existing one. I am considering that myself as the firewire packed it in again last month and I had to jump over to the other 5v regulator to get it going again, even tho it was only 0.2 v short! Cheers, Sandrine
Jun 20, 2011 | Phonic Helix18fw 18 Channel Mixer with...
I get a distorted sound from my speakers throug a Phonic Helix Board. It is connected on a PC through Fire Wire. The distortion is also there while using microphones or other inputs (CD-players etc.). It...
Hallo landgenoot ;)
It seems it is a power supply problem; distorted sound, no meters, solo buttons not working, headphones low level and distorted. One of the power supply voltages might be too low or even missing. The Helix series mixers use mainly 4 supply voltages: + 15 V and - 15 V for the analog part (audio), + 5 V for the DSP and logic and +48 V only for the phantom power. If for example the + or - 15 V is too low, clipping of the positive or negative parts of the waveform (dependng on which voltage is too low) will occur. If possible, first measure the voltages coming out of the power supply. You could use a metal part of a jack as ground reference.
For the FireWire board an extra voltage supplied by the switched PSU is used. It is specified as +12,2 V, but I measured 14 V. This voltage is lowered to + 5 V by a resistor on the FW board and a 7805 regulator. (Not very efficient!) But as far as I can see, the FW voltage is not the problem here. I have some service documentation of the Helix series mixers (12, 17 and 24, so if you need more you can conatct me: frankdevries [at] versatel.nl.
Groeten, Frank.
Mar 18, 2011 | Phonic Helix18fw 18 Channel Mixer with...
I have a Phonic Helix Board 24 firewire MK2 When i open it all the peak led stays open I think the power suply is busted I need an expert
The power supply uses three, 3 terminal regulator chips. You should find +/- 15 volts and +5 volts DC from those. There are two fuses, one for each polarity. If one of those is blown, that would cause the problem and one would need to find WHY it blew before replacing it.
You need to find a competent electronics repair person.
Nov 02, 2010 | Phonic Helix18fw 18 Channel Mixer with...
I have a Phonic Helix Board 18 Firewire MKII. It is not picking up any signal from my computer. I have tried having a DI'd bass straight into it and it works fine. My PC recognises that the devise is...
It may be your old computer was running XP operating system and your new one Win7... There is a lot of incompatibility with different operating systems. You can try searching for a compatibile driver. If you cannot find one, the best thing might be to back-step to your old compatible OS and driver.
Oct 03, 2010 | Phonic Helix18fw 18 Channel Mixer with...
Pc not recognizing phonic helix 18 universal mixer
I have a Yamaha AW1600 and I had to go into my firewall settings and add it to my exceptions to allow the program access to my computer through the firewall. This may help. Thanks!
May 30, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Phonic Helix18fw 18 Channel Mixer with Firewire Logo
156 people viewed this question
Top Phonic Music Experts
Ben Armstrong
Marvin
Marvin
NOEL
NOEL
Are you a Phonic Music Expert? Answer questions, earn points and help others
