Question about Astoria Argenta SAE-2 Espresso Machine
Steam smells odd and affects milk taste.
Hi
Our Astoria SAE/2-GL has started to give off a strange smell from the staem wands and makes the taste of the milk a bit strange. Has anyone any ideas how to resolve this please?
Clean and purge your wands EVERY time you use them. If you leave milk on the wand, it gathers at the lowest point ( where the holes are) and as the wand cools, the air/steam, in the wand contracts, the condensation reconstitutes the mil, the contracting air/steam creates a vacuum, and sucks the milk back into the wand. If you turn the machine off, the cooler does the same thing.
You're reboiling milk at 250F + again and again.
Posted on Nov 03, 2011
    President:
  • 1,618 Answers
The boiler is contaminated with milk and needs to be descaled and cleaned.
Posted on Apr 15, 2011
Water mixd wih steam
THERE IS A MIXTURE CONTROL, THAT U CAN SET ACCORDING TO UR DEMAND. ON MOST MACHINES ACCESSIBLE FROM THE TOP WITH A +/- SIGN NEXT TO IT
Apr 27, 2014 | Astoria Argenta SAE-2 Espresso Machine
How to fix the wand on the espresso machine, not enough pressure is coming from the wand to steam the milk.
First check the steam wand tip to make sure it is not blocked. If it is clear remove the wand and run it under a faucet to make sure it is not blocked, it water flows freely, then the problem is on the fitting that connects the valve to the boiler, remove fitting and check, if clear check the boiler fitting, use a screwdriver and clear the fitting on top of the boiler.
Jun 28, 2011 | Astoria Compact CKXE Espresso Machine
My steamer wand has an awful odor everytime I try to steam something! I have cleaned it (even soaked in baking soda!) and the problem won't stop. Anyone else have this problem?
This is a common problem for the commercial espresso machines, Due to lack of cleaning of the steam wand after they finish frothing milk.
The milk flows back to the boiler and the water gets contaminated with milk.
Does the steam smells like rotten milk? If the answer is yes, you have contaminated water and or lines.
If not may be there is a lot of IRON in the water.
Run a descale cycle.
After you are done frothing milk, wipe the steam wand with a wet towel and open the steam valve for 2 seconds, close it and that's it.
Jan 15, 2011 | Saeco Starbucks Sirena Espresso Machine
When I steam my milk it tastes burnt and there is a strong burning odor.
The boiler needs to be cleaned, it is contaminated with milk. Check the water from the tea spicket, if it smells funny or it is discolored then the boiler is contaminated, if not then the problem is at the steam wand and steam valve.
Jan 11, 2011 | Astoria Compact CKXE Espresso Machine
Burnt smell is coming from steamer wand
Boiler is contaminated with milk, check the water from the tea valve, if it smells the same or has swimmers, boiler needs to be descaled, if no floaties then removes steam wand and soak in purocaff for a few hours, then clean. Always flush ssteam wand before and after every drink.
Mar 04, 2010 | Nuova Simonelli Mac 2000 I Group Espresso...
STEAM PROBLEM
Does the steam itself smell, or just the milk. If yes on the steam run the descale again. If no on steam then check the perfect cream wand the black plastic arm connected to the steam wand, dissamble and clean, make sure all the holes are clear.
Mar 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
The steam coming out of my espresso smells burned
Try descaling amchine to clean boiler.
Mar 12, 2009 | Saeco VIA Venezia
Hot water no steam low psi
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Nov 17, 2008 | Astoria Argenta SAE-2 Espresso Machine
Coffee tastes burnt/No steam for froth
I don't know about the burning business but I had the same problem with the steam wand. the first thing I did to solve this problem was to take small object like a needle or safety pen and insert it into the base of the steam wand. (I have feeling that most problems related to the steaming wand are due to deposits clogging the wand itself.) After I cleared out as best I could I used vinegar and water to help remove any calcium deposits. Sure enough, after inserting the needle into the wand steam began to flow again.
Feb 26, 2008 | Mr. Coffee ECM10
Astoria Argenta SAE-2 Espresso Machine Logo
306 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
obsteiner
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
