Question about Thexton 383 Power Steering Belt Tightener
Little leak need to change belt
Need to know where the pwr steering or coolant line is 1995 nissan max
  • 35 Answers
Easiest way to find the Power Steering is to locate your power steering resorvoir (Where you fill your power steering) and follow the lines off it. Easiest way to trace and locate your lines.
Posted on Jul 31, 2010
2009 nissan altima is making a noise ...i think its the tension. has anyone ever heard of that?
older model altima need drive belt tension adjustment at 7500 miles intervals, the new models altimas has a automatic belt tensioner.i you hear noises belt tensioner could be failing.or could have leaking coolant getting on drive belt due to water pump gasket leaking or pump leaking.or alternator power steering pump could be failing many things will cause drive belt to make high squeak noises.
Oct 09, 2012 | 2005 Nissan Altima
Belt keeps popping
which belt? a/c, alt,or pwr steering.
Jun 06, 2012 | 1995 Nissan Pickup
Power steering is out what do i need to do to fix it
replace power steering pump, belt, replace with clean power steering fluid, replace power steering hoses as well. if its making a sound look for leaks, try stop leak first.
Jun 30, 2010 | 1995 Nissan Maxima
Need to replace pwr steering belt...it fell off. want to replace
The tensioner is spring loaded and there is no setting. It floats with the belt. It's the pully with no groves that applies pressure to the back of the belt. Good luck. and be carefull.
Sep 24, 2009 | 2002 Nissan Frontier Crew Cab
Nissan xterra 2003 car noisy problem
If it's the water pump there should be water leaking, if it's the steering pump the noise  would change as you turn the steering wheel left to right. If it's constant, it could be just old belt and bad idler and tension pully. Start buy praying a little water to the belt while the engine is running and if the noise goes away, the belt is in time to be chaged. If the noise is still there, then most likly it's the ilder bering or tension bearing. Good luck
Apr 08, 2009 | 2003 Nissan Xterra
Leaking coolant by the alternator bracket
Yes there is an "O" ring in there. However that plastc tube always breaks or cracks. You can get that tube kit from your local parts store. Remove the serpentine belt and pwr steer pump, The pump has three bolts accessed through the pwr steer pump pully you will see the holes in the pully to get to bolts DO NOT REMOVE HOSES. Now give the pump gentle persuasion uppward, but it will come, make sure the back of the pump isn't obstructed by the fuel rail you will see what I mean when you look at it. Remove all other parts in your way, hoses etc., be gental. When you remove the tubes note where each end goes the "O" rings have different colors 1 is redish orange & the other is purple this should give you an idea what goes where. Just remember to bleed coolant system of air when done. There's a metal tube in front that goes under upper motor mounts, it has bleeders at each end. Jobs not hard just requires time and patience. Oh, add a little permatex (black) around "O" rings when installing for added security, just push in firmly these are fragile. You might have to remove coolant reservoir bottle as well if it's in your way.
Mar 01, 2009 | 2002 Pontiac Grand Prix
Power Steering Fluid
sometimes adding brake fluid to the power steering pump will stop the leak if its not to bad.you may have to keep adding as it leaks down untill you use about a bottle ,before it stops the leak.
Feb 22, 2009 | 1995 Nissan Maxima
2002 Jeep Grand Cherokee leaking coolant and power steering fluid
Just a heads up, $10 bucks will buy you a seal kit for the P.S. pump. I topped mine off for a couple months, then the oring on the high pressure line (from pump, front center) blew and dumped the reservoir in a matter of miles.
The line can be a stinker to get off, recommend driving the car for a few minutes to heat up the pump a little. Don't forget the 20MM wrench.
Feb 18, 2009 | 2004 Jeep Grand Cherokee
Thexton 383 Power Steering Belt Tightener Logo
91 people viewed this question
Top Thexton Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thexton Hammering Expert? Answer questions, earn points and help others
