Question about LG FLATRON L1717S 17" LCD Monitor
LG Flatron LX151 i have it, and my problem is it cant open or power on, when i plugging it into AC it just turning the blue power indicator for a second and nothing next
    Brigadier General:
  • 10,406 Answers
Which will be cheaper:
* paying a technician $50 to $75 for labour/parts to fix it?
* paying $50 to $100 to buy a new 17-inch LCD monitor?
Posted on Jul 31, 2010
Blue light flashing
The flashing blue light indicates that the power supply has failed
May 14, 2013 | LG 22" FLATRON LCD Monitor
I can not turn off the sleep mode on my LG Flatron monitor W2361VG-PF
This monitor has a manufacturer's defect in two of the wiring harnesses: the harness going from the controller board to the power button (4 grey, 1 blue wire) and from the power button to the side controls (3 grey, 1 blue wire). Open the monitor (snaps apart, no screws) and gently tug on each wire individually. One of them is causing the problem. You can replace the harnesses, try to fix them, or solder new wires directly to the pins.
Feb 16, 2013 | LG FLATRON W2361V 23 inch LCD Monitor
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
Dec 17, 2012 | LG Electronics W1934S Flatron W1934S...
W2361v will not turn on.
This monitor has a manufacturer's defect in two of the wiring harnesses: the harness going from the controller board to the power button (4 grey, 1 blue wire) and from the power button to the side controls (3 grey, 1 blue wire). The insulation was not stripped properly from the blue wires on any of the 4 connectors. You will have to open the monitor (snaps apart, no screws) and replace the 2 blue wires. You can solder jumpers to the pins or replace the entire harnesses.
Sep 06, 2012 | LG FLATRON W2361V 23 inch LCD Monitor
LG Flatron 575MS 15.1" LCD Monitor Need 24 volt power supply
alkarim 15, Are you looking for an "open frame" switcher or a "open frame" linear dc supply. Does it need to have regulated output or if linear type just brute force output.What is the current requirement of the circuit you will use with the power supply? Have you checked www.jameco.com or www.digikey.com or www.newark.com . Does it need to be AC or DC output? 12fixlouie
Aug 27, 2010 | LG Flatron 575MS 15.1" LCD Monitor
Blue on indicator light not working
If turned on and working good, just the indicator light that does not show.
This indicates that the indicator bulb is bad or burnt.
All you need to do is to replace the indicator bulb of your monitor.
Take care.
Apr 25, 2010 | LG Flatron L1919S LCD Monitor
Turned my tv off last night and then when i tried
power supply has blown. you need to replace the bad capacitors on it. common problem
Jan 01, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Can't get monitor to power on
I have a similar switch on mine, although mine is a Gateway. So my solution is going to assume the same indicators and functionality.
On mine, a blue-violet power switch indicates it is off, red indicates standby mode, and blue to indicate it is on and/or searching for a signal. When turned on (blue), the monitor will go to standby mode (red) after 3 to 4 seconds if it does not detect a source signal. So if you toggle the power switch to blue and it soon changes to red, you'll need to check your signal, cable, or possibly for a bad source connection on the monitor.
Oct 12, 2009 | LG L206WTY-BF Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
LG FLATRON L1717S  17" LCD Monitor Logo
190 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
