Question about Onkyo TX-SR606 Receiver
ONKYO TX-SR606 stand-by light starts blinking immediately
After approx 1yr of performing perfectly the stand-by light now starts blinking immediately after power on. i tried the VCR/DVD + POWER ON switch to CLEAR however to no avail. any other suggestions
  • 17 Answers
SOURCE: receiver - onkyo tx-sr606 problem
if the speaker settings are deactivated, there is no other way but to reset the receiver back to factory settings. press and hold down vcr/dvr and then press standby. you will the word reset and that should activate your speaker set up again. hope this helps. ^_^
Posted on Dec 09, 2008
  • 17 Answers
SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Posted on Dec 16, 2008
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
  • 5 Answers
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
I had this problem, and it was one of the speakers. I disconnected the right rear speaker and now it works fine. I asked a guy at Visions how to solve it so I can hook my speaker back up and he said that banana plugs prevent wires from crossing and sending a backwards signal (causing the receiver to turn itself off). Hope that helps!
Posted on Dec 20, 2009
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Onkyo sr606 service manual
Go to Onkyousa.com, move mouse cursor to support, click on owner's manuals, click on receivers, click view archived receiver models, click TX-SR606 (both"quick setup" and "HTS 7100 for the full manual").
Oct 18, 2012 | Onkyo TX-SR606 Receiver
Is it odd that my TX-SR606 Onkyo Receiver wont go into stand-by? It turns off but the standby light never lights.
try reset. push and hold vcr1 and then press power button while unit is on this will reset back to factory default
Apr 24, 2010 | Onkyo TX-SR606 Receiver
Hello. I have Onkyo tx-sr606 home theater
could be a bad soldered joint or loose connector, even a bad earth in the secondary power circuit.
Feb 27, 2010 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Jun 11, 2009 | Onkyo TX-SR605 Receiver
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Onkyo tx-sr606b no power - blown fuse?
it either a bad fuse or your transformer that is blown
Jan 06, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR606 Receiver Logo
532 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
