Question about Apex Digital GB43HD09 43" Rear Projection HDTV-Ready Television
What parts needed to fix APEX Convergence Issue.Chips or boards?
To fix convergence problem on Apex GB43HD10
what parts do I buy?
Online tech stores carry ''CONVERGENCE BOARDS'', 2 of them, for this model. But google search has people saying to replace two CHIPS beginning with STK. TV MODEL IS G43HD10
See below parts.
APEX 8667203150T Recycled parts are harvested from returned products. These parts are in perfect working order and guaranteed to perform to the same standards as original parts. Usually ships in 4 - 6 business days
APEX 8667204140T CONVERGENCE BOARD ASSY Usually ships in 4 - 6 business days
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It is convergence (STK) ICs (Chips) which needs to be replaced and not the convergence board. It’s not a difficult job if you want to do this yourself. To start with you’ll need to open the back of the unit and then replace the ICs (STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts. Please see the pictures to recognize STK ICs (Chips) shown with arrows---
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
I need a repair kit for a apex gb43hd10 convergance problem
Check the site www.TvRepairKits.com - they will not have your model listed but they can build a customer convergence kit for many models. You just need to send them a few photos of your boards.
Apr 18, 2013 | Televison & Video
How do i fix the convergence on my apex gb5801
replace the convergence ICs very common problem for all rear projection Tvs that develope a convergence control issue.
Jan 02, 2013 | Televison & Video
Need diagram to rebuild and fix convergence issues
In a APEX set change the convergence chips (2) AND use the original remote to adjust the set. There are several sites like TV parts.com that sell kits based on brand and model number.
Apr 30, 2012 | Apex Digital GB43HD09 43" Rear Projection...
Apex Mod# GB43HD10 The picture is now blurry or wavy.
Sounds Like your convergence ICs big black ICs will part number on them example STK394-020 Call Mats for Parts on ICs 1-800-628-1118 Also Call Encompass you can order whole Board if you want to you just unplug old board and plug in new 1-800-638-3328
Oct 01, 2009 | Apex Digital GB43HD09 43" Rear Projection...
My apex gb5108 convergence lines wont line up.I'm watching 3d
possibly the convergance ics have failed or convergance module
soldercon or both not a very costly repair
Aug 25, 2009 | Apex Digital GB5108 51" Rear Projection...
Apex GB43HD10 Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 10, 2009 | Apex Digital GB43HD09 43" Rear Projection...
Apex model GB43HD10 need instructions for service menu
Decrease vol to 0 on remote. Then press menu on the front panel while holding mute on the remote. An s appears on upper left side of screen. Press pip Ch+ to scan menu, Press CH+ or - to select and press VOL + 0r- to adjust items
Jun 16, 2008 | Televison & Video
Apex convergence
Try resoldering the convergence chips.
Nov 08, 2007 | Apex Digital GB5108 51" Rear Projection...
55 apex HD tv
The APEX and most rear projections are notorious for poor solder joints. The convergence circuits on your TV get very hot and the solder joints weaken over time. In your case, the convergence STKs are the large chips mounted to heat sinks right up front on the left hand side circuit board. Remove the board and resolder the STKs using a good low wattage iron. If this doesn't fix your problem try replacing the STKs. They aren't that expensive. They have 15 or so legs so you'll need some skills removing them. Good Luck!
Sep 28, 2007 | Apex Digital GB5108 51" Rear Projection...
Convergence and wavey picture problem
Actually you have 3 problems. The two that you listed and the third which is: Apex does not support their units. Ask anyone who has tried to get any service. Your problem sounds like a bad digital convergence box. I fix this problem several times a week but on name brand sets. Cost is usually less than $100 for the part. Some problems with Apex equipment can be fixed if the part is a common off the shelf part. That is not the case with your problem. Apex equipment is cheap for a reason. All posts that I have read say that they do not last long and you can't get parts. That has also been my experience as a technician. We don't even accept Apex units for repair anymore. Next time spend the extra money to buy a name brand unit and it will more than likely be repairable.
Jun 01, 2006 | Apex Digital GB5108 51" Rear Projection...
Apex Digital GB43HD09 43" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
