Question about Bulova 96D10 Wrist Watch
How to take links out of 96D10 bulova watch - Bulova 96D10 Wrist Watch
  • 2,334 Answers
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Jul 31, 2010
How do you set the times and date on this watch?
Go to http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine Star&gender=1 and you will see a list of the current models. I could not find yours among them but since they are all bacially the same watch, you should be able to find one that is similar to yours.
Click on the watch illustration and you will see a link to operating instructions, which you can download.
Dec 12, 2010 | Bulova Marine Star 96B99 Wrist Watch
I have a bulova ladies watch serial number on back is p77309 i would like to get it working help,
You will need to contact Bulova or a local watchmaker. Here is a link for Bulova:
http://www.bulova.com/contact/contact.aspx
Good luck.
Aug 12, 2010 | Bulova Watches
Bulova automatic How old and value.....number 3865924
To get exact age and price, follow this link:
At the bottom of page you will find CONTACT US. Just click on it .
Rate me, please.
Aug 05, 2010 | Bulova Watch
I need to add 2 links to a ladies bulova watch model 98r98.
Contact Bulova for additional links, 800-233-3350. You will need the watch model number and the case number (it's in the back beginning with "C".
Aug 09, 2008 | Bulova Watches
Bulova 96D10 Wrist Watch Logo
216 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
