Question about John Deere 22HP Hydrostatic 42" Riding Mower
John Deere 115 will not start - just a clicking
John Deere 115 automatic will not start - just a clicking noise when I turn the key. I charged the battery and checked all the connections. ???? I do not have PTO but I did check the seat safety switch and it is connected.
nova2nv
  • 197 Answers
SOURCE: John deere x320 will not syart. if one coil ground
The wiring harness under the engine shroud that feeds both coils has a diode on each of the wires that connects coils.The diodes keep each coil from grounding each other out so when one diode goes bad it will only run on the cylinder with the strongest coil.Order new harness from Deere,cost less than $30.
Posted on Dec 23, 2009
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 130 Answers
SOURCE: my john deere jx75 lawn mower won't start up.
There's a lot of safety features on tractors. Your owners manual would be the best place to check. I'll throw out a common spring time start up issue: dead battery. If you didn't have it on a trickle charger over the winter, tractor batteries die in 2 or 3 years. If it has started recently, check for a blown fuse.
For safety features, make sure you're sitting in the seat, brake on, clutch fully depressed, and any attachments (blades) disengaged.
Posted on May 02, 2009
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere 2010 utility tractor, lights come on
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 10, 2009
Belt diagram for john deere 115
Follow the link and then shchol down to the 115 model John Deere Belt Routing Guide
Jun 27, 2017 | John Deere Garden
I have a john deere la 115 trys to turn over but not enough power to start
Check the battery condition make sure its fully charged and the terminals are clean and tight, if ok the starter may need repairs.
Jul 03, 2016 | John Deere Garden
I have a John Deere LA 115 hydrostatic transmission that's going on 8 years old. When I crank it there is a noise that almost sounds like something is loose under deck. When I press clutch, it stops. What...
Check drive path for the idler pulleys. One is a flat and the other is V type. The bearing go dry on lube and require replacement,
See Circled items below.
Mar 31, 2015 | John Deere Garden
I have a John Deere D130 riding mower that will not start. When I turn the key I get nothing. When I jump from the battery + to the solinoid the motor cranks. I have replaced the seat switch, the brake...
check out all the safety switches , they make a circuit on closed , = make sure your safe not in gear etc , put a shunt direct and make sure you have cuircuit
Jul 19, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
I have 2000 john deere 420 and it wont turn over
The starting circuit is dependent upon the clutch safety ans PTO being off. Here are some steps to take:
1. Ensure battery is fully charged
2. Turn key on and turn PTO on then back off. Listen for clunk
3. Press clutch in fully and turn key to start position. If still no sound at all, hold key in start position and move clutch foot up and down, listening for solenoid click. If click but no crank, starter or solenoid or battery cable connection is bad. Start by wiggling cables, looking for any looseness. Next check solenoid and cables. If that doesn't fix it, starter or solenoid may be bad. There may be a fuse in the circuit. Check them out also.
if it cranks but doesn't start, you have a fuel or ignition problem. Good luck. Let us know what you find
Jun 22, 2014 | John Deere 420,1020,2010,2020,2510,2520...
How to test a solenoid for a John Deere 115 Lawn Tractor with 42" deck?
http://www.greenpartstore.com/assets/images/instructions/2012/am138497_installation_instructions.pdf
John Deere Starter Solenoid Kit AM138497
First make sure the negative battery cable is making good contact on the frame or what ever part of the mower it is connected to. Make sure both battery cables are clean and not corroded and are tight. Then try to start the mower. If it works, fine. If not then you will bypass the solenoid and see if the starter turns the engine. To bypass the solenoid take a car jumper cable and connect one clamp to the terminal on the solenoid that goes to the battery ( see the diagrams in the links above) Turn the ignition switch to the on position. Take the other end of the same color of the jumper cable (say you'll use the red clamps) and touch the clamp to the other large terminal on the solenoid, which goes to the starter. If the starter turns the engine, then you know the starter is good and that the solenoid is bad. If the starter does not turn the engine then the starter is bad. make sure you DO NOT touch the jumper cable to the starter case or any other ground.
May 18, 2014 | John Deere Garden
John deere d110 clicks but won't start
Starter solenoid. 10 bucks. just fixed mine, exact same problem.
Nov 09, 2013 | John Deere D110 19.5HP Single Cylinder...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
John Deere 22HP Hydrostatic 42" Riding Mower Logo
304 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
