Question about Kenmore Heating & Cooling
Need new fan motor comp works where can i get motor the ac is a window unit kenmore plasm aire
  • Kenmore Master
  • 8,220 Answers
Try Sears Beta Parts
Remove the front cover of the window unit to access the model number location.
Yesterday I went to my sisters house. Her ac's fan was not on. I took some side cutters and make a hole big enough to reach inside and turn the condenser fan on the back side of the unit. I added some HVAC oil to the motor. Don't know how long it is gonna work but it is working now.need new fan motor comp works where can i get - ca02c58.jpg
Posted on Jul 31, 2010
Kenmore central air conditioning unit tripping breaker each time we turn it on.
The breaker tripping when you turn the unit on indicates a 'direct short' and 99 out of a 100 times the short will be either the outside fan motor or the compressor itself. Either way - you will need a qualified serviceperson to diagnose this problem correctly and make the needed repairs.
Best solution is to call AC person.
However, here's a good way you can get it down to either the fan motor or the compressor.
(1) With all power OFF - disconnect the wires to the fan motor
(2) turn on AC unit (a) if breaker trips it means the compressor is probably the shorted component. (b) if breaker DOES NOT trip and the compressor runs - it means the fan motor is shorted.
(3) If breaker tripped with the fan motor disconnected meaning the compressor is probably shorted you can then (with ALL POWER OFF) 'disconnect the wires going to the compressor' and re-connect the fan motor wires. Turn on power - and if fan motor runs (with compressor wires off) you know it's the compressor that is shorted.
After all this you will now know which of the two (compressor or fan motor) is shorted.
If it's the fan motor you can with 'limited mechanical experience' change the motor yourself, but if it's the compressor you will need to call a serviceperson because of the expertise needed to replace the compressor.
Jun 05, 2011 | Kenmore Heating & Cooling
The AC unit turns on and I can cycle through the options in order to adjust the fan speed however the fan does not start in any of the three settings. The ac unit produces cold air, however the fan does...
You say the unit produces cold air ??? where are you getting the cold air from???
If your fan does not run in any speed F1, F2 F3. and a funny smell sounds like the motor is bad
Mine works in F2, F3 but not in F1
Apr 12, 2011 | Kenmore 75085 Air Conditioner
I need an installation manual for ac 75135 This is a closeout.
It is the either the fan bearings is going out of the motor or you just might clean the fan blades it the fan blades has any play on the shaft probably the bearings are going out to the motor.
Jun 03, 2010 | Kenmore 75101 Wall/Window Air Conditioner
Kenmore AC unit's fan won't blow at all
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Jul 30, 2009 | Heating & Cooling
Hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Mar 31, 2009 | Frigidaire FAC125P1A Window Air...
Fan motor
yes that moves air through the whole unit.
Aug 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Broken AC window unit Kenmore
starting capacitor is bad (THE STARTING CAPACITOR IS A BIG METAL BLOCK MOUNTED ON OR NEAR FAN MOTOR)
Jan 17, 2008 | Heating & Cooling
Window AC Unit
Hi, Sitting for a year or more don't hurt them but bugs dirt and water could. Depending a lot on the size and quality of the unit, there are usually no charge ports on a window unit and the parts and tools to charge it would probably be about the price of a new unit. If the fan motor is running and the compressor is running and it wont cool, I would call around and see what someone would charge to repair the leak and recharge it. The price would be better if you delivered it to their shop for repair. If the fan runs with no compressor, probably needs a thermostat or switch. No fan, Needs a fan motor or has something blocking the fan motor from turning, stick, dirt daubers nest, whatever. In most cases though, if its not a simple fix, A new unit would probably be your best bet. Hope this helps. kstfas
Aug 27, 2007 | Fedders AEQ07FBG Air Conditioner
Heating & Cooling Logo
88 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
