Question about Aiwa CDC-X227 CD Player
The CD player isn't inserting CDs properly. The eject button didn't work and a CD is stuck in the slot. All other functions are working (display, volume, radio) and the reset button didn't resolve this issue.
  • gme7 Aug 02, 2010
    The CD player isn't working. The automatic feeder slot isn't "grabbing" the CD and playing it.
    All other functions (display, volume, radio) are working. Using the reset button didn't resolve the issue.
  • 4,737 Answers
Follow these simple steps:
1. Turn off the Player.
2. Disconnect the Ac Cord (or could be Dc cord in some cases).
3. Keep the unit Off for few minutes.
4. Reconnect the power cable.
5. Power on the player and hit the cd-tray with a screwdriver as it boots.
6. If the Cd which is already on the Slot and is not placed correctly, use the screwdriver to align it with the tray so that it'll sit on the slot properly.
7. Now, press the eject/close button.
You'll be able to eject it and remove the cd or you can try closing the tray with the cd. If the problem persists, let me know.
I wish you good luck.
Thanks for using FixYa.
Posted on Aug 02, 2010
  • gme7 Aug 03, 2010
    hanks for the tip - the stuck CD is removed now. Unfortunately, the automatic CD feeder isn't working and so CDs can't be played. All of the other system features are working, including display, volume and radio. Any advice would be appreciated.
  • 3,230 Answers
Well you can please follow the below steps -
1. Take a blank/useless CD and place it about 1 inch deep into the slot.
2. Press the 'Eject' button and gently wiggle the CD around. If this doesn't work, repeat and try to get the blank CD below the the jammed CD, and gently pry the target CD upwards.
It helps you to remove the stucked cd.
If this player further eat cd then there is some alignment problem in the player cd tray. Please post comments for further help or information.......
Good Luck!!
Thanks
Posted on Jul 31, 2010
  • gme7 Aug 01, 2010
    Thanks for the tip - the stuck CD is removed now.
Cd won't eject on a 2010 buick lacrosse cxl
Try inserting an "old" CD into your radio, just under the lip of the stuck CD...this can properly trigger the "eject" function on your CD player...Hope this works...
Feb 15, 2016 | 2010 Buick LaCrosse CXL
How can I eject stuck 3 CDs from CD player + GPS 2006 toyota camry grande?
there is small pinhole on the front of the player, you need to push thin stiff wire (paper clip straightened up will do) and this will mechanically release lock on the players doors, retract the doors fully and remove the dvd's.
Dec 29, 2014 | 2006 Toyota Camry
Help!! I have a library CD stuck in the CD changer. I can see it but it will not eject...it won't even acknowledge that it has a CD in the changer. I have tried tweezers, switching CD slots and trying to...
TRY TURNING OFF CD PLAYER.WAIT 10 MINUTES THEN TURN CD PLAYER BACK ON THEN PRESS THE EJECT BUTTON.SOME TIMES CDS PLAYERS GET HOT WHEN PLAYED FOR A LONG PERIOD OF TIME.MY CDS SEEMS GET STUCK WHEN I PLAY CD PLAYER LONG TIME.SOMETIMES IF CD DONT COME OUT .IF IT STICKING OUT JUST A LITTLE.TRY PUSHING BACK IN CD PLAYER THEN EJECT IT.THIS TRICK WORKS SOME TIMES.
Mar 11, 2011 | 2002 Ford Escape
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
After jumping a dead battery (hot shot) the CD player died. It gave an error: it thinks that there are no cds inserted when in fact there are 5. It will not eject and I cannot insert. My hope is that I...
After my car battery went dead my cd player is stuck. It won't play, or eject and it thinks there are no cds in it when in fact it is full. HELP!
Oct 31, 2010 | Car Audio & Video
Cds are stuck in the default cd player of 2001 Dodge Intrepid. How do I get them out?
The first step is turning the car off. Then before turning the key back on, push and hold the Eject button then turn the ignition on. If the CD fails to eject then you can use a old CD and try to insert it into the CD Player, just as it try's to take your second CD pull it out and hit the Eject button again. This will usually get a Dodge CD player to Eject.
If this fails then the CD player must be removed and a manual eject can be performed.
May 15, 2010 | 2001 Dodge Intrepid
5disc multiple choice cds stuck in slots how do i
Have a look for a small hole in the front of the CD player - this is the emergency eject button. Find a paper clip, unwind it and then press the paper clip through the hole - the CD should then eject the first CD and you will then be able to eject the others.
Apr 28, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd is stuck the reject botton won't work
1 Try this: While holding the SELECT button, press the ATT button for 2 secs. It will rest the player and eject the CD 2 To unlock the CD While pressing CD, press and hold 0 for more than 2 seconds. “EJECT” appears on the display, and the CD eject from the slot the slot # If above does not work you have to open the cover and remove CD manually
Nov 19, 2009 | JVC KD-S5050 CD Player
Just stopped playing CDs
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Nov 26, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Aiwa CDC-X227 CD Player Logo
47 people viewed this question
Top Aiwa Car Audio & Video Experts
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
