Question about Pentair 2" Pvc, 3 Way Lube Free Diverter Valve, with 2.5" Slip Outside
How do I remove a Pentair 2'' slide valve, it doesn't pull up out of its position after removing the top holding bracket, seems to be stuck and I don't want to force it for fear of breaking the mechanism.
    President:
  • Pentair Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Keep trying. The o-ring(s) are probably rolled up and you need to force it out. I have never broken the body after yanking several of those out so I doubt you will break the valve. If you do it can be replaced without getting a whole new filter...just in case.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 31, 2010
  • schristi69 Jun 16, 2011
    Sometimes the top section does not want to line up with the cylinder. This usually happens when the o-ring lube has gone. You have to disassemble the valve and work the plunger out. This can be quite a pain. You CAN break the valve. The plastic handle is subject to weakening by the sun and will snap off. A new plunger assembly is not cheap. The valve body of mine has cracked at the screws that hold the assembly in place. Replacing the whole thing with a multi-port valve. Never did like this type of valve
Where can I find helpful instructions for replacing (removing old and installing new) thermocouple on Pentair 250k minimax ch NG mv? Thank you.
Simple:
  • Insecure bracket holding the pilot assembly to the burner tray
  • now, remove the pilot assembly from bracketry
  • unscrew old pilot generator/thermo pile or thermocouple
  • new may have a clip instead of threaded nut
    • diameter of hole is same so it should just snap into place
  • in reverse order resecure the pilot bracket to burner tray
May 30, 2014 | Pentair 250k Minimax Ch Ng Mv Heater
How to replace the gasket on a sm2-pp3 multiport valve assembly
make sure you note the position take a picture remove screws holding top of multiport on lift off there is the gasket clean off some have to be glued back on then put back together
Oct 06, 2012 | Pentair 112 Multiport Valve Kit for FNS...
263064 valve problems
http://www.pentairpool.com/pdfs/270163.C-TwoPositionSlideValve.pdf
This is the manual for your valve. Maintenance section tells how to take it apart.
Jul 30, 2012 | Pentair Push Pull Valve 7-1/2 in....
Pentair sm2-PP3 multiport valve assembly
note position or take picture before taking apart then remove top screws take off top remove old gasket install new one careful some have to be cemented into place
Mar 18, 2012 | Pentair 112 Multiport Valve Kit for FNS...
The setting position lable has fallen off the top of the valve
Call Pentair Water at 800-831-7133
They will probably mail you a label for free. Be sure to tell them if you have a sand or D.E. filter
Jul 19, 2011 | Pentair 2" Slip Universal Hiflow Valve...
How do you remove left door panel
at the top and bottom of the right side of the left door panel on the back there are 2 spring loaded L shaped locks. Just pull the two at the same time and slide the door out.
Jan 17, 2011 | Pentair Minimax NT Heater
Pentair sand dollar filter is leaking water when backwash not on
If you have the valve in the Filter position and it is still leaking water out the backwash line, the problem is the Spider gasket inside the valve itself. However, the valve that usually comes with the Sand Dollar filters has the gasket glued to the Diverter, and has to be replaced as one piece, sorry about that!
If you have a manual on the filter, go to the parts page dealing with the valve. If you do not have a manual, the link below will take you to one online:
http://www.pentairpool.com/pdfs/SandDollarOM.pdf
The part that needs replaced in Item #8. What you will do when you get the replacement part is to stop your system, close any valves to stop the flow of water so you do not loose too much. Then you will open up the Air Release Valve and release all the pressure in the filter. Pentair usually recommends that you wait at least 30 minutes after this to make sure there is no presure in the tank. Once this is done, you will remove the screws holding the top part of the valve to the bottom, place the screws is a safe place so yo do not lose them - did that once!- and pull the handle portion up, as a single piece.
Place the top part on a flat surface, and remove the Handle Screw (Item #3) while holding down on the top of the valve. This will help keep the spring in the handle from popping up on you! Slowly raise your hand to allow the spring to expand, no parts will go flying this way! (did that one too!) Then just pull out the old Diverter and replace it with the new one. Reassembly is a bit difficult because of that spring, but once the Handle Screw is in place, it is pretty easy. You DO NOT need to lube the gasket/diverter, so you just line up the diverter sections with those in the bottom of the valve and replace the screws. Just in case, the WASTE position is always OVER the Waste Port on the valve.
Jul 10, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
Pentair filter
I am sure that you already have an answer to this, but IF you can not read the valve label sticker, call the Pentair Customer Support 1-800 number. They will send you out a new label, free of charge.
For referrence, the waste position is ALWAYS over the waste port on the valve.
Jun 14, 2009 | Pentair Meteor Above-ground 22" Sand...
Pentair 2" Pvc, 3 Way Lube Free Diverter Valve, with 2.5" Slip Outside Logo
256 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
