Question about GPS
My ETEN X500 phone GPS not working - GPS
  • 19,396 Answers
Hi.
If the system is new, ensure that you have been driving for at least half mileor so , the GPS will sync with the satellite when it is moving.
Try removing the GPS battery overnight to drain power and reset the Sirf chip.
If that is not the problem, then try downloading a different GPS software. See the links below:
http://www.visualgps.net/BeeLineGPS/
Download Beeline, install it and check if it does detect your gps (port 4 or 7). If it does not detect the GPS and the blue led does not come on, then there may be an hardware failure.
If still no luck, try using the utility spGPSView to reset the unit, here the download: Download/spgps.zip .
Check also the repair tips illustrated here.
Posted on Jul 31, 2010
My phone Ten X500 shuts down by itself when i every i carry it in my pocket ( but with out squeezing it) & i have to reboot it every time. Is it battery problem. Thanks in advance
I am not sure if this has been solved for you, but I have had the same problem it wad due to loose pin which is designed to turn off the device when the back cover is removed. The solution to my problem was a piece of paper which I plug into the hole with the pin. SOLVED!
Oct 19, 2010 | Eten Glofiish X500 GPS Pocket PC
My x500 freez upon boot
there's a small capacitor on the eten x500 mainboard, very close to the reset button. it's a pull-down capacitor that counts tao-time for entering your unit to bootloader.
I believe this capacitor is broken, and device cannot enter to windows OS and keep the bootloader mode.
you can try to download the ETEN last rom image and try to flash it, maybe it will be the solution for you. but I guess the capacitor in the mainboard could be the real reason. that's from my technician experience..
Aug 29, 2009 | Eten Glofiish X500 GPS Pocket PC
Hbnivn@yahoo.com
Aquy se encuentra el manual y la descarga de software para su Glofiish.
Manual /software /applications
Aug 22, 2008 | Eten Glofiish X500 GPS Pocket PC
Eten Glofish X500
what is the installer of x610 for Computer
Jul 03, 2008 | Eten Glofiish X500 GPS Pocket PC
X500 glofiish
visit www.pdaviet.com
Get a cooked rom, follow the instructions on how to Flash your rom to pdaviet.
I suggest pdaviet x500 version3 (V3)
All you problems will be cured.
Feb 21, 2008 | Eten Glofiish X500 GPS Pocket PC
Won't turn on
Your Mainboard is faulty. I had an Eten M600 like that before and ended up it die totally. Eten had many problem with their board. If you still have warranty, contact them for a replacement. Nothing you can do about it since the board is failed to boost due to Power failure.
Feb 16, 2008 | Eten Glofiish X500 GPS Pocket PC
Gps not connecting
Can be two things,
You dripped your device and the wire from the antenna has broken, or you have an old amplifier chip which has burned out. It a known issue.
In either case, send it back if its under warranty. If not, you can do it yourself is you have a good steady hand and can solder well.
take a look at www.eten-users.eu
Jan 15, 2008 | Eten Glofiish X500 GPS Pocket PC
GPS Logo
37 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
