Question about HP Pavilion DV6910US Laptop
Bootmgr is missing startar ej vad att göra? - HP Pavilion DV6910US Laptop
    Guru:
  • 261 Answers
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully.
8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Posted on Dec 24, 2010
ATI Rage 128 Pro 32MB ultra GL AGP waar kan ik een driver vinden voor windows 7
http://download.cnet.com/32mb-ati-rage-128/3000-2108_4-63707.htm
lOm paketet inte r?tt http://download.cnet.com/2000-20_4.html p? hemsidan b?r du se en fliken S?k bara in vad du letar efter (att vara exakt) som du kanske m?ste prova en n?gra g?nger f?r att f? det r?tt
Oct 20, 2011 | Ultra ATI Rage 128 Pro Graphic Card
Reparar mi paint drive kinston
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope this helps you
Klicka p? Start Kontrollpanelen administrive datorverktyg Management h?rddisk h?gerklicka p? enheten v?lj Egenskaper Klicka p? verktyg du b?r se p? Kontrollera nu Klicka p? Start tv? boxar automatiskt ?tg?rda filer och s?ka efter och f?rs?k att reparera skadade sektorer plats sedan ett kryss i b?da rutorna och v?lj sedan kontrollera nu b?rjar eller s? kan du kryssa i en ruta att sedan ?terv?nda efter avslutade den f?rsta reparationen sedan ?terv?nda och markera den andra rutan ska du inte g?ra n?got medan chkdsk p?g?r n?gon ing?ng kan skada den h?r enheten
Jag tyckte att du f?r b?st resultat genom att kryssa i en ruta sedan ?terv?nder efter att det har slutat sedan markera den andra rutan
hoppas att detta hj?lper dig
Sep 18, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Nao roda o dvd..
Klicka p? Start p? panelen Verktyg administrive, Datorhantering Enhetshanteraren scrolla ner CD-DVD ROM-enheter du kan se ett gult fr?getecken? h?gerklick kommer du att ha m?jligheter att uppdatera drivrutin ?terst?ll tidigare drivrutin, eller v?lj egenskaper Allm?nna fels?ka, v?lj f?raren klicka f?r att installera om drivrutinerna p? Uppdatera drivrutin eller avinstallera sedan installera om detta inte l?ser problemet kan det vara ett problem i registret om du inte kan se din h?rddisk i Utforskaren
St?ng alla ?ppna program
Klicka p? Start, K?r och skriv regedit och tryck p? Enter
Klicka p? plustecknet (+) bredvid f?ljande mappar
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Kontroll
Klass
{4D36E965-E325-11CE-BFC1-08002BE10318}
Denna mapp ?r DVD / CD-ROM-enhet Klass Beskrivning i registret. Leta efter n?got av f?ljande namn i den h?gra kolumnen.
?vre Filter
L?gre Filter
?vre Filters.bak
L?gre Filters.bak
Om n?gon av ovanst?ende knappar som visas i steg 4 visas, h?gerklicka p? dem och v?lj Ta bort
Efter bort nycklarna, st?ng Registereditorn
Starta om datorn
?ppna Den h?r datorn och kontrollera om din cd-eller dvd-enheter har ?terv?nt. Du kanske ocks? vill ?ppna Enhetshanteraren och kontrollera att den gula utropstecken och felkod p? CD eller DVD-enheten ?r borta. eller
du kanske m?ste fysiskt koppla ur leder till denna CD / DVD sedan in dem igen detta b?r aktivera guiden Ny maskinvara eller
kanske du m?ste avinstallera starta om datorn installera din DVD / CD sedan installera om drivrutinen f?r denna enhet
Om datorn levererades med ett moderkort disk drivrutinerna kan vara p? det
Klicka p? Start Kontrollpanelen administrive verktyg Datorhantering Enhetshanteraren scrolla ner cd DVDROM enheter om du ser ett gult fr?getecken eller utropstecken? ! eller ett r?tt X h?gerklicka m?ste du uppdatera drivrutinen eller
v?lj Egenskaper allm?n fels?kning, v?lj f?raren klicka f?r att installera om drivrutinerna p? Uppdatera drivrutin
Sep 09, 2011 | LG GSA-4160B DVD±RW Burner
Hej jag har prolim med lexmark cover open
Det kan vara patronerna i bärselen. öppna skrivarens lucka och ta bort bläckpatronerna. Kontrollera cylinderampullen område för några hinder i bärselen vägen. Om inga, stäng locket. Koppla ur och tag bort skrivaren till strömkällan att återställa sig själv. När skrivaren slås , sätt tillbaka bläckpatronerna och kontrollera att de sitter i rätt och säkrade. Stäng locket. Försök skriva ut igen.
May 04, 2011 | Lexmark X3480 All-In-One Printer
Kan inte instalera skrivaren Lexmark E232 till min dator, Fujitsu Simens. Finner inget installationsprogram att ladda ner.
Du f?r tillg?ngsupport.lexmark.com webbplats f?r att ladda ner och installeraskrivardrivrutiner. Kontrollera att du valt r?tt filter f?r dittoperativsystem, n?r du installerar drivrutinen, dubbelkolla anslutningen mellandatorn och skrivaren. P? skrivare och fax kontrollera att r?tt skrivare ?r valdsom r?tt standardskrivare. F?r ytterligare hj?lp,kontakta Lexmarks tekniska support.
Jan 20, 2011 | Lexmark E232 Laser Printer
Hur gör jag för att skydda min router genom att ha ett lösenord????
TR?DL?S TRYGGHET FR?GOR
Steg 1: Anslut router - Computer (Wired)
Steg 2: ?ppna Router Setup genom att skriva http://192.168.2.1 i adressf?ltet i Internet Explorer
Steg 3: P? v?nster under tr?dl?sa Klicka p? Wi - Fi Protected Setup
Steg 4: L?mna l?senordsf?ltet tomt och klicka p? skicka
Steg 5: Inaktivera det och klicka p? Verkst?ll f?r?ndringar
Steg 6: P? v?nster under tr?dl?sa klicka p? S?kerhet
Steg 7: Aktivera 64 bitars WEP
Steg 8: Skriv ett 10-siffrigt nummer p? nyckeln 1 (2 i varje kartong)
Steg 9: Klicka p? Utf?r ?ndringar
Steg 10: till v?nster under tr?dl?s klicka Kanal och SSID
Steg 11: ?ndra den tr?dl?sa kanalen till 6
Steg 12: ?ndra SSID till ett annat namn (utan mellanslag)
Steg 13: Klicka p? Verkst?ll ?ndringar
Steg 14: Nu Scan och ansluta till detta n?tverk (tr?dl?st)
L?t mig veta om det fungerar
Oct 19, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hej!Jag har en CASIO EX-Z150. När jag sätter på kameran säger den att kortet är låst. Jag vet inte vad jag ska göra. Det går inte att göra nånting med...
Ibland finns det en liten str?mbrytare p? sidan av SD-kortet som g?r det m?jligt att skriva till kortet av och p?. Om det misslyckas ?r det f?rst med ett annat minneskort.
Aug 19, 2017 | Casio EXILIM Zoom EX-Z150 Digital Camera
Har en nyköpt ML-1640 som använts vid ca 50 utskrifter. Problemet är, Att Plötsligt fastnade Ett papper Nästan färdigskrivit och den röda Lampan började lysa.Den...
>> Have a his newly bought ML-1640 used for about 50 prints. >> The problem is that suddenly stuck a paper written nearly finished, >> and the red light began to shine. >> The red light Must visa green normally. >> Tips on what the error is desired. A part of a piece of paper is jammed somewhere along the "path" that the paper must travel. Take the printer to a certified technician, and have them repair it. Perhaps, the "warranty" will pay for the repairs, or will provide a replacement ???
Sep 15, 2009 | Samsung ML-1640 Monochrome Laser Printer
Installation av ati radeon 9950
)*&((&^*^&^%()^&^)*&%)_^_(^&*)^*&%^&)*^_
Jun 01, 2008 | Computers & Internet
HP Pavilion DV6910US Laptop Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
