Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
My John Deere lawn tractor starts and runs ok but sputters and quit after usinng a short time and then is hard to restart. Putting gas directly into the carburator and it starts right away.
    Problem Solver:
  • 5 Answers
If you have a fuel solenoid switch on the float bowl you can remove it and replace it with a plug. You can leave the plug disconnected. Did it to mine and it runs better than ever. I think the solenoid get s hot and shuts off the fuel
Posted on Aug 01, 2010
180 john deere riding lawn mower
Your deck belt slipping. It need adjusted or replaced
Aug 11, 2014 | John Deere Garden
My john deere push mower starts fine mows for 10 min quits wont start so I took the the gas cap off looked at it put it back on push the prime bulb 1 time it started ran for 10 min quit did the gas cap...
I'm not sure of the model number of your mower or engine to know the fuel and carburetor set up. I do have one easy thing to try though as it sounds as if a vacume is building up in the tank. Try putting a half of tank of gas in it, leave the gas cap off, and see if it continues as it was or if it runs ok. If this stops the issue your cap vent is pluged up. I hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 03, 2013 | John Deere Garden
I have an L120 lawn tractor with a B&S 22hp v engine that will not start. I have changed the spark plugs, gas filter, both air filters. It cranks / turns over very strong but does not start. It...
Sounds like gummy gas. Try a shot of carburetor cleaner down the fuel line to the carburetor. Or take the carburetor apart and clean it, squirting through all the tiny holes and inspecting the float needle for abnormal wear. replace the float needle assembly if necessary.
Oct 17, 2011 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LT 133 lawn tractor quits running after about 10 minutes.
Will it restart right away or does it have to cool down? If it has to cool down, then run it until it quits. Next remove the plug, reattach the plug wire, and ground the plug to the block. Finally try to start it with the key. If you get no spark or very weak spark then the ignition coil needs to be replaced.
Let me know how it goes.
Aug 18, 2011 | John Deere Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
475x runs out of gas during normal ops. Leave key
the gas cap quit venting the tank...it's causing a vacuum that the pump can't draw fuel against...to check, loosen the cap and cut some grass...if it works, clean out the hole in the top of the cap...if not replace the pump..
Apr 18, 2010 | Garden
Have a John Deere L111 lawn tractor with running problems
I had the same problem and I figured out that it was the small hole on top of the gas cap. There is a vent hole on the top/middle and this got plugged with debris and caused a vacum in the gas tank which caused the engine to sputter and kill. Good luck!
Apr 12, 2010 | John Deere 1:16 Scale H Tractor with hay...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,282 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
