Question about GE Advantium 120 Convection/Microwave Oven
My GE Advantium 120 microwave went out. Nothing. I've taken it down from over the stove and have gotten the outer cabinet off. I've replaced the only fuses I see that are replaceable. I still get nothing. No power at all. Can you help?
  • ccollcl Aug 01, 2010
    My GE Advantium 120 microwave went out. Nothing. I've taken it down from over the stove and have gotten the outer cabinet off. I've replaced the only fuses I see that are replaceable. I still get nothing. No power at all. The outlet plug and circuit breaker are fine. Can you help?
    President:
  • 2,030 Answers
Did you replace the fuse with one made especially for microwaves (available from radio shack)?
If you replaced the fuse with a correct one, and you still get nothing, and you are getting power to the main transformer inside, then chances are you transformer or magnetron have cooked; it will be cheper to buy a new oven than fix that one, as the parts will cost more than most new units, and that doesnt include the labor charges you will have to pay to get someone to properly install them.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Aug 01, 2010
  • 532 Answers
Hello
This is a problem that many Advantium owners seem to have.
If it is still on warranty, please do no hesitate to take it back to the manufacturer.
But if not, check the circult and the plug if they are okay.
Thanks for contacting Fixya.
Posted on Jul 31, 2010
  • ccollcl Jul 31, 2010
    Its not under warranty. The breaker and outlet are fine. Any other suggestions?
  • Rahman Rufai Aug 01, 2010
    Hello Sir
    Please i will like to clarify this question. Is the microwave oven dead or it does not heat food? Please let me know in time.
    Thanks.
How to replace door switch on advantium
Happened to my 2005 Advantium120 twice, both times after extended cooking/simmering on the cooktop (17" below). Solution was to leave unplugged for a good 48 hours (to dry out?) then plug in again and all is good. GE says to either raise the microwave 4" or stop boiling pasta on the stove, neither a good solution. Good luck!
Jan 28, 2013 | GE Advantium 120 Convection/Microwave Oven
No power, i have power to the outlet but nothing on the unit works.Is there a fuse?
remove the cover ... look on the floor of the unit near where the cord enters the cabinet.
Oct 12, 2009 | GE Advantium 120 Convection/Microwave Oven
How do I replace the fuse in a GE Advantium SCA1001KSS?
under the outer cover on a fuse clip its a special fuse avail at hardware stores
Oct 08, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
Sep 05, 2009 | GE Advantium 120 Convection/Microwave Oven
Need to know how to remove Advantium 120 convection/microwave oven Model SCA1000DWW03 from mounting above stove so that it can be taken to repair shop - problem is completely dead after power surge during...
Usually there are 3 or 4 mounting bolts located in the floor of the cabinet above. First you will have to disconnect the power and then the duck work if the unit is ventde to the outside. To remove the unit requires two people, one to support the unit and the other to remove the bolts. If you are doing it alone, quite difficult, you'll have to juryrig a deadman support. Ther is a wall plate behind the unit that has a lip that the back bottom of the microwve is locked into. After the bolts are removed slowly lower the front until you are able free the unit from the lip of the support plate.
Jun 28, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Opinion
I have had an Advantium for about 3 or 4 yrs and would use nothing else! When this one wears out I will buy another one! I hardly ever use my regular oven any more! Hope this helps.
Feb 02, 2009 | GE Advantium 120 Convection/Microwave Oven
Arcing
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
Nov 16, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120
no they do not. I just replaced one of these they aren't hard but it would be very difficult to do without takeing it down. due to the price of these I strongly recomend you call your local appliance service
Apr 17, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
93 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
