Question about Dell Dimension 4600C PC Desktop
Trouble removing case on Dell Dimension 4600c
I have read the instructions and I know you have to press the buttons on the top and bottom of the tower to open the case. The top button pops without a problem, but the bottom one seems to be stuck. The tech support at Dell wasn't able to give me any advice aside from "push harder." Anyone have a better idea?
    Scholar:
  • 103 Answers
Try this...
I work on these systems on a weekly basis and they can be very difficult to open. I would make sure that you have already removed the feet from the bottom and turn it so that the heavy side (technically right side up) will be facing the floor. Place the palm of each of your hands on each of the buttons and squeeze the system as hard as you can while holding the system maybe an inch or two off of the floor. The plastic buttons basically cover a metal release tab that is actually part of the frame. All of the clamshell type cases are tough to open because of this. Good luck.
Posted on Apr 24, 2008
How to remove hard drive from dell tower
Open clam-shell type case by pushing buttons on rear top and rear bottom of case and pulling case open like a book. Once case is opened, you\'ll see the hard drive in the right half (as viewed from the back of the PC) Pull the power and data cable from back of the hard drive. Squeeze ends of green plastic slides and pull hard drive from enclosure.
Apr 21, 2014 | Dell Dimension 8300 PC Desktop
I need to replace the motherboard battery on this Dell Dimension 4600 tower. How do I open the casing ?
All the PC are more or less the same thing...
Here's a video tutorial of how to open it.
Aug 24, 2011 | Dell Dimension™ 4600C PC Desktop
How to open desk top tower
Hi
This model has a large indented button on top rear and on the bottom rear. Press both and the case will open like a **** shell. Do this only when the power is unplugged.
Jun 06, 2010 | Dell Dimension 4600 PC Desktop
Unable to remove cover from dell dimension 8400 desktop pc
This Dell Support, and the Service Manual for the Dimension 8400,
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
In the Service Manual main menu, left-click on - Opening the Computer Cover
1) Computer off, and unplugged from power. (Always unplug the power cable from the surge protector. Then if the power cable needs to be removed from the computer, do so)
2) Remove all cables to the computer
3) Lay the computer on it's Right side.
(As you face the computer, your right side is the computers Right)
4) There is a Release button on the Top of the computer case, and a Release Button on the Bottom of the computer case.
These are located at the Rear of the computer.
The preferred method of opening the computer case, is to press one release button in at a time, and slightly lift up on the side of the computer case, where that release button is located near.
Then go to the other side of the computer case, press this release button in, and lift up on the computer case.
The computer case opens like a clamshell. The computer case is hinged at the front.
Example:
Computer laying on it's right side. Press the Top release button in, and lift up on the computer cover located near the Top.
Now press the release button on the Bottom. Lift the computer case up.
The computer case opens from the back, towards the front, like opening a car hood.
Feb 18, 2010 | Dell Dimension 8400 PC Desktop
Removing sides on a Dell Dimension 2400 tower
Lay the case on its side and depress the "buttons", there are is one on either end. The case opens like a **** shell, if you start to open it and it feels very heavy on the top, stop and turn it over so the motherboard is toward the floor, that will make it easier on you.
Sep 08, 2009 | Dell Dimension 8300 PC Desktop
I need printed instructions on how to install Dell Dimension 4600c power supply. I ordered the part but it came with no instructions.
Power Supply Removing the Power Supply caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in your Owner's Manual or Product Information Guide. caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before removing the cover.
  1. Follow the procedures in "Before You Begin."
  2. Remove the fan assembly.
  3. Disconnect the AC power cable from the AC power connector on the back of the power supply.
  4. Unplug the DC power cables from the drives and system board.
  5. Remove the four screws that secure the power supply to the back of the computer.
OR
As you add more devices to your Dell Dimension 4600 desktop, it is important to ensure there is enough electrical power being fed to the components. While the 250 Watt power supply that comes standard with the Dell Dimension 4600 is acceptable at stock settings, it is almost certainly not capable of providing power for many more devices such as graphics cardsmag-glass_10x10.gif and multiple hard drives. If you add such devices, you also should upgrade your Dell Dimension 4600 power supply.
Aug 28, 2009 | Dell Dimension 4600C PC Desktop
I have a dimension 4600c. installed a new power
The power supplies have extra connectors which are not used.
Try doing a system restore to an earlier date when your computer was working ok.
Restart your computer and hit F8 while it is booting. When the menu comes up, select "Last Known Configuration"
This will bring it back to a time when it was working.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 11, 2009 | Dell Dimension 4600C PC Desktop
How to open case for a dell dimension 4600c computer.step -by step
Here's a Diagram Snap-Shot of the first step. (just enter the verification code and view.)
That's it for opening the case!
More information (General Everything about and how-to Guide) on your Dell can be found HERE.
The Dell Guide Link is a .pdf file from Dell's Support Section.
I Hope This Helps.
Jan 30, 2009 | Dell Dimension™ 4600C PC Desktop
Do not know how to open a Dell Dimension 4300 case
Lay your computer on the side there should be a big button on top and also one on the bottom push both of these buttons and pull the sides back toward you.....it really takes two people to do this...
If this is not your type of case you can go to the dell website and they have instructions for different cases.
Dec 06, 2008 | Dell Dimension 4300 PC Desktop
Dell Dimension 4600C PC Desktop Logo
585 people viewed this question
Alun Cox
