Problem setting up printer sharing. Windows XP hub connected by ethernet cable. Windows Vista wireless across the room. XP can see and access Vista. Vista can see but cannot access XP. "Logon Failure" Please help.
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the issue.
Thanks for using FixYa.
Posted on Aug 01, 2010
  • Susy Hammermeister Aug 02, 2010
    Actually, I remembered that my Brother printer 3040CN is networked so I connected the printer and modem directly with an ethernet cable and that problem is solved. But I still can't see my XP files from the Vista computer - denied access to them - although I can access the Vista files from the XP computer.
    I'm going to withdraw my question, since printing was the most urgent problem I had. Thanks anyway.
Cisco access point
How to configure wireless access point using a laptop
Wireless technology makes connecting to the Internet possible from anywhere within the range of the network. Unfortunately, not all Internet-capable devices have wireless technology, and many still require an Ethernet port connection. If you have a laptop with a wireless card and an Internet connection, you can make the laptop a wireless access point and share that connection with other devices, whether your laptop runs a Windows or OSX operating system. Windows computers allow other devices to access the wireless network via a physical connection to the laptop, while OSX computers allow AirPort equipped devices to connect as well, creating a second wireless bubble for the network.
Instruction:
WINDOWS
1 Turn on the laptop and the device with which you will share the connection. Ensure the laptop's wireless card is turned on and you have an Internet connection.
2 Connect an Ethernet cord to the port on the laptop, and the other end to the receiving device. You need to make the connection first, or you will not be able to access the sharing options for the connection.
3 Open the list of network connections on the computer. In Windows 7 and Vista, access this list by typing "Network Connections" into the Start menu search bar and pressing "Enter." In Windows XP, click on "Network Connections" in the Network and Sharing Center section of the Control Panel.
4 Right click on the wireless connection and select "Properties," then navigate to the Sharing tab. This tab will not appear unless both devices are connected.
5 Check the box marked "Allow other network users to connect through this computer's Internet connection." Click "OK" to save the changes.
OSX
1 Click on the Apple menu and select "System Preferences." Click the "Sharing" option, then choose "Internet Sharing."
2 Select the Airport and wireless network in the "Share your connection from:" drop-down menu.
Select an output format for the connection in the "To computers using:" drop-down menu. Choose "Ethernet" for a physical connection or "AirPort" for wireless broadcasting.
Turn on the device you wish to receive the connection. Connect the devices with an Ethernet cable, or turn on the receiving device's AirPort card and connect wirelessly.
Dec 12, 2011 | Computers & Internet
Motorola SBG900 LAN problems
This is simply a firmware problem of your Motorola Router so what is the best thing to do here is to update the firmware of your router, you can download the latest firmware from Motorola's web site....
Oct 21, 2008 | Computers & Internet
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Print from vista to xp with usb connected lexmark 2350 results in access denied error after timeout. Vista access shared printer through a wireless router. Any recommendations?
Okay, I need to understand your topology a little better. You have two PCs, one using Vista and one using XP. Both PCs are connected to the Wireless modem. The printer is connected to the XP PC and shared across the local network? When the Vista unit sends a job to the printer, you get an access error message. Is this description accurate? Normally this would be caused by the sharing settings on the XP unit. Please make sure you have the sharing options correctly set on the XP unit and then get back to me if I've given you an incorrect path to follow. Don
Jun 06, 2009 | Lexmark X2500 All-In-One Printer
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Cannot connect to wifi from bt home hub any suggestions. laptop higrade 8615gtx
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Dec 10, 2008 | Computers & Internet
Printer sharing
Appreciate the direct "Ask Me".
Initially, pls try enabling the Share feature of the printer in XP. Pls go to Start, Printers & Faxes, right click on the printer you want to share, click on Sharing...follow on screen instructions. A few suggestions:
  • verify that the Vista and the XP uses the same Workgroup;
  • verify that other shared folders and files could be viewed from each other;
  • verify that each could access the internet from a single connection.
A few questions:
  • do you have a router or a hub;
  • how are the XP and Vista connected to the network, LAN cables or wireless.
  • confirm that it is a HP > PSC 1510 All-In-One InkJet Printer that is connected to the XP machine.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
Just purchased laptop with windows vista home premium
If your PC has a wireless card, you can setup an AD-HOC network :
If your PC is XP: http://www.microsoft.com/windowsxp/using/networking/setup/adhoc.mspx
If your PC is Vista: http://windowshelp.microsoft.com/windows/en-us/help/293c504f-b944-4d5d-835c-f080129bd5dc1033.mspx
If your PC only has a wired Ethernet connection, you may still connect the two using a Wireless Access Point/Router.
Once you have the two computers connected, you may do whatever networked operations you would like:
File & Printer Sharing is the most common:
XP: http://www.wellesley.edu/Computing/FileSharing/Windows/win2kxp.html
Vista: http://www.windowsnetworking.com/articles_tutorials/File-Print-Sharing-Windows-Vista.html
Aug 01, 2008 | Apple iPhone 3G
Share printer
First you have to set up a home network between both your computers, once that is established run an networking cable to your printer it should all be ran through a networking hub so all machines can communicate with one another
Jul 05, 2008 | Brother MultiFunction Center MFC-440CN...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
