Question about Dell OptiPlex GX620 PC Desktop
USB port problem
I have a Dell Optiplex GX620. I have had a Epson photo printer connected via usb (the only option on this printer). One day the computer didn't recognize my printer. I have tried the printer on other computers, and it works. When i try to install the driver for epson printer again the computer have to recognize the printer to install the driver. When the computer detects the printer as unknown device the installation aborts. I have tried all usb ports on the computer and everytime it fails. What can be wrong with my usb ports?? I have several other products like camera and external hard disc and they work fine on every usb port.
  • kobjella Apr 24, 2008
    I belive my usb port drivers are up to date. When i try to update them the message i get is that there is no newer driver available..
    I will try to update the Intel Chipset Software Installation Utility.
    Can anything go wrong in this update or is it straight forward?
  • firespotts Oct 03, 2008
    same problem - tried the chipset update and when I restart, it keeps asking for files from the WinXP Pro Svc Pk2 CD... I re-point it to c:\windows\system32\drivers, where the files it is looking for are... still can't communicate with the printer. I know the port is good because my usb mouse worked fine in it. Help???
    Scholar:
  • 103 Answers
I would try first of all making sure that all of your drivers are up to date. I am saying this because it is always a good first step, but I am not 100% confident that this will fix it. There are a few updates that are listed as URGENT for your specific computer. The link to your drivers is below. The main one that concerns me is the Intel Chipset Driver located under chipset. This is listed as URGENT and may be a solution to your problem. The chipset is part of the motherboard that can be responsible for controlling your USB ports. If this does not remedy the situation I would contact Dell support for a possible solution.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PLX_GX620&os=WW1&osl=en&catid=&impid=
Posted on Apr 24, 2008
  • Richard Wilbur Apr 25, 2008
    Its straight forward. Even if it fails during the install, it wont hurt anything, you will just need to reinstall it.
On my dell optiplex gx620 all of the usbs front and back dont work after the windows loading screen but power is working, usb light works. i dont no what to do i have enabled them in bios and default...
my dell optiplex gx620 is coming on but its not passing the bios revision or the boot up page i have tried every thing removing the small battery in the mother board unplugging the hard drive, i even busted the whole system and it still not coming on. i have triied sending it into safe mode and the 1234 light are comming on i have runed out of option and i dont know what to do.this all started 3 days when i turned off the computer tried to put it on but after it came on pass the boot up page the screen was blank
Oct 01, 2010 | Dell OptiPlex GX620 PC Desktop
Problem with dell optiplex 620 keyboard and mouse failure when plugged into usb port
the first thing you need to check is if the same keyboard and mouse is working with another pc.if it doesnt then replace the keyboard and mouse.if they work fine on the other system then go to start and right click on the computer option and then click on manage,once you have done that click on device manager.now look for universal serial bus controller and expand the option by clicking the plus sysmbol beside it.once you have done that right click on each of the usb root hub and click on uninstall.once all of them have been uninstalled.close all the windows and restart the pc.now it should work fine.
Jan 14, 2010 | Dell OptiPlex GX620 PC Desktop
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Want to connect a Mac laptop to a EpsonStylus Photo R340 printer.
Hi
Try connecting the printer to a different usb port if you have extra port and make sure the connection is direct from printer to your mac
Hope this helps
Nov 14, 2008 | Epson Stylus Photo R340 InkJet Printer
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
My usb ports aren't working at all
try reinstalling the chipset drivers from
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=27&impid=-1&servicetag=&SystemID=PLX_GX620&hidos=WW1&hidlang=en
Select the Operating system
The Category as Chipset
Importance should be All
Click on the Intel driver
Download now
File name is R132539.EXE
If this does not work you will be having 2 usb at the back and in the front of the system.IF the back does not work than you need to get a local tech out at your place as it is a problem with the USB controller on the motherboard and that might have to be replced .If it is the front USB (Only if you have them) then there is a cable coming from the USB controller to the fromnt usb ports that cable might have got unplugged for that you need to open the tower.But i would still recommend a local tech.
May 26, 2008 | Dell OptiPlex GX620 PC Desktop
Ubs plug in
Looking at the picture of your computer, I dont see any colored usb sockets. If it indeed the usb port you want to use,anyone will do.
Dec 19, 2007 | Dell OptiPlex GX620 PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
360 people viewed this question
Alun Cox
