Question about Kenmore 24 in. 17462 / 17464 / 17469 Built-in Dishwasher
Kenmore elite model 665-17469300 will not wash when sclecting smart (or any cycle) smartwash and rinse/drain lights come on for about 15 seconds than go out the dishwasher does not start thank you jeff
  • 3,230 Answers
Well first of all you can check the door and make sure it is closed and locked. If door is not locked, the dishwasher will not operate. Listen for the door switch to "click" when the door is closed. If it doesn't, you may need to replace it. You can also try to reset the dishwasher by press these -
High Temp + heated Dry
Please post comments for further help or information......
Good Luck!!
Thanks
Posted on Jul 31, 2010
  • 1 more comment
  • njartisticim Jul 31, 2010
    ok just trided the "reset " dishwasher went through several cycles about 2 minutes than stoped with same results as first this did not repair the machine
    thanks jeff
  • Mukesh Kumar Jul 31, 2010
    Ok, you can please check out the door switch. Make sure that you here a "click" sound when close the dishwasher door.
    yes the door switch does click i also pulled pannel checked switch it is working correctly also i have looked at suply hose and discharge hoese both are working freely
    thanks jeff
I have a Kenmore Elite Smartwash QuitPak9 washer. I keep getting error messages 02F and Sud or 5ud . Seems washer will not drain , Can get it to drain sometime , no clog
its a suds sensor error. meaning tom much or the wrong detergent was used and it has clogged the wash cycle, you will have to try to run rinse cycles over and over to u clean it out if u can, some machines have an auto clean cycle for this problem, it is difficult to deal with as I have the same issue with one of mine and still not running right
Jan 07, 2017 | Kenmore Washing Machines
Kenmore smartwash quietpak HE4t does not complete cycle and flashes F then H continuously
From what you're describing it sounds like the cold water line is blocked or restricted or the inlet electro valve is defective.. Most rinse cycles are cold fills. Another possibility is the drain hose is air tight or too low creating a siphon condition
Jan 05, 2017 | Kenmore Washing Machines
Kenmore elite smartwash
remove the drawer and clean it and see if that solves the problem
Mar 27, 2014 | Washing Machines
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
I have a kenmore elite washer and the light is on that says controls locked
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 10, 2011 | Kenmore Washing Machines
I have a kenmore smartwash quietpak 9 HE 5T front loading washing machine for about 2 years. Today I did a load and the water will not drain from the washer so I had to pull the clothes out and wring the...
Likely the drain hose is kinked or blocked...Or the pump filter blocked or pump is faulty. Most likely the filter needs to be cleared. This should be accessed via a small hatch at floor level. Or behind the kickplate. unscrew filter and clean. Make sure the machine has no water in it. Leaning it back against the wall will help with visual inspection as well. Make sure coins haven't jammed in impeller. Good luck.....Nomess
Apr 18, 2010 | Washing Machines
I have a kenmore elite smartwash quiet pak9 he4t water wont drain on the final rinse cycle. The only error message i get a the letter F. Does anyone know what that means?
Dont know the code but i would imagine it means the water has not emptied in the max time preprogrammed,either the drain is slow or blocked or drain pump is faulty
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Open Questions:
Kenmore 24 in. 17462 / 17464 / 17469 Built-in Dishwasher Logo
196 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
