Question about Sony Computers & Internet
CANT FIND DEVICE DRIVER FOR SONY AD5260S,WINDOWS
CANT FIND DEVICE DRIVER FOR SONY AD5260S ,WINDOWS CANT FIND MY DVD ROM
    Brigadier General:
  • 10,406 Answers
The device-drivers for CD/DVD units are "built-in" to Windows XP/Vista/7.
So, you have either a "dead" drive, or some other problem (data and power connectors not connected to the drive) or some BIOS-configuration problem.
Posted on Jul 31, 2010
Optiarc DVD RW 24x SATA - AD5260S not detected in Windows 8.1 pro x64
I would first go to bios settings and make sure the SATA is set to "enabled" or "on" or something like that. Otherwise, Windows 8.1 would probably detect the drive.
Nov 29, 2017 | Computers & Internet
Sony CRX835E CD-RW/DVD-ROM free drivers
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps you
Nov 22, 2011 | Sony Computers & Internet
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Nov 22, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My computer see the unit and this not work S561 Magneto Optical Drive not driver for download for sony company.
you might have to physically unplug the leads for this cd/dvd rw then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
Jun 07, 2011 | Sony RMO-S561 Magneto Optical Drive -...
My cd-rom cannot read any cd files, the error display says about a problem with ISO. my cd rom is SONY brand
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Hope this helps
May 29, 2011 | Sony cdrs-1209 CD-ROM Drive
Windows cannot load driver for Sony CDRW/DVD X 33OE
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 30, 2011 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
My Sony CRX320EE-88 cant read bootable cd/dvd. Yes it registers at the bios on boot up and its also detected on my windows start up but when it comes to playing cd's and dvd's, it cant read both of them....
make sure that the cdrw/dvd rom is getting enough power test all leads that are attached to the cd/dvd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 04, 2011 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
MY SONY CRX835E-DF CDRW WILL NOT WORK. i AM TRYING TO FIND A DRIVER FOR IT TO FIX THE PROBLEM
Hello mychella513, hi, there is no need for you to find the device driver for your sony combo, because its already present in windows. If you cannot power on the device or the computer cannot detect your drive, its defective, Windows has already installed the device driver for CD/DVD for your computer.
Aug 09, 2010 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I'vd got not driver
Windows 2000 and XP and Vista and 7 have "built-in" device-drivers to allow you to read "data" files from CD and/or DVD drives.
However, you need software, such as 'PowerDVD' in order to "play" pre-recorded audio/video content recorded on DVD media.
See: http://www.CyberLink.com for information about 'PowerDVD' software.
Jan 08, 2010 | Sony DVD-ROM DDU1615-ZB 16X IDE 512KB 100...
After installing windows 7, the LG DVD drive doesn't work and windows says it cant install the driver
Many older ICH7 chipset drivers as well as generic derivers has been removed from the winodws Latest Built, for you it it seems the cd/dvd rom drivers are missing.
I here give the link uploaded by me, which contains the driver for CD/DVD ROM fro windows 7, Please open device manager and manually locate the CD/DVD rom and select the .inf file to install the driver
http://rapidshare.com/files/297330669/CD_ROM_Drive.rar.html
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Rename CD-ROM Drive.txt to CD-ROM Drive.rar!
@ADDeveloper
Try the Intel package(link posted before), that's an Intel mobo.
Oct 24, 2009 | Computers & Internet
Computers & Internet Logo
1,329 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
