Question about Sport & Outdoor - Others
We want to assemble our Lifetime World Class Portable Basket ball Hoop but need assembly instructions. FixYa has referred me to dazdi.com where I found the correct document but it doesn't allow printing. The manual is protected. Please find me a version for assemble Lifetime World Class Basketball Hoop Product 5298 that can be printed at home. Thank you.
  • 10,594 Answers
I just checked that assembly instruction manual, it is printable and it is not locked.
You can save manual file in computer by clicking save icon (floppy) or let download complete manual in browser window and hit printer icon to get it print.
Below image shows how I checked it.
Hope these info will help you.
Let me know if you have additional question about printing.
Thanks.
Posted on Aug 01, 2010
Need manual for lifetime portable basket ball hoop CB01400-1
You should be able to find it here,let me know if this doesn't solve your problem,are you sure that is the correct name for product ??....https://www.google.com/search?client=aff-maxthon-maxthon4&channel=t27&q=manual%20for%20lifetime%20portable%20basket%20ball%20hoop%20CB01400-1
May 11, 2017 | Lifetime Sport & Outdoor - Others
I was looking for the assembly instruction for this older model.
I was looking your other question about Classic Sport Triple Threat 222 portable basketball hoop assembly instructionsand couldn't find it on line so didn't answer it. But looks you was looking assembly instruction for that older model? Maybe you could provide the denimination for that older model
Jul 13, 2015 | Sport & Outdoor - Others
I lost some screws to my hoop I was wondering what store would I be able to buy them from its a lifetime world class hoop I'm in the mankato mn area
Is this the Barrel Nut or the Screw that runs into it?
An older hardware store should have them if you show them the screw.
They're also available on eBay but I will guess it is a metric size and the ones on eBay are hardware sized, like for holding chairs together.
201results for barrel nut
Mar 15, 2015 | Sewing Machines
Ryan's Room Home is Where the Heart is Classic Dollhouse
Hello, Jon -
First, please use the Edit feature and remove your email address from your question, unless you want to receive a lot of spam and phishing email. A Fixya.com answerer will not email you.
Small World Toys manufacturers Ryan's Room toys, including doll houses. I suggest you contact Small World Toys directly and ask if assembly instructions are available for the doll house.
This is the link to the Small World Toys Contact Us page:
http://www.smallworldtoys.com/index.php/contacts/
Best wishes.
Jan 30, 2018 | Small World Toys
Need instructions to replace door latch-kenmore elite top loader
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Assembly instructions for portable basketball hoop
we put all three poles into one by mistake on our new portable hoop we managed to get the screw out but cannot get the poles apart help!
Sep 10, 2009 | Huffy Sport & Outdoor - Others
Sport & Outdoor - Others Logo
149 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
