Question about GE Refrigerators
My refrigerator is not keeping food cool, so I upped the temperature but that didn't help. My freezer wasn't keeping my bread and rolls frozen so I upped that temperature control also. Now I have a chemical smell, mostly in the freezer but also the refrig. The frig came with the house and I have had the house for 15 years. Any ideas what is happening
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezermy refrigerator is not keeping food cool, so I - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 31, 2010
Why is everything in my freezer solid but my bread?
A REFRIGERATOR IS MEANT TO KEEP THINGS COOL.LIKE THE NAME INFERS,A FREEZER FREEZES.YOU BREAD IS PROBABLY WRAPPED UP IN A NYLON OR A FOIL.THESE WILL ONLY BE COOL TO TOUCH BESIDES YOUR BREAD CONTAINS PRESERVATIVES AND BREAD MATERIALS.WITH THIS YOUR BREAD CAN STILL STAY FRESH IF KEPT IN ROOM TEMPERATURE AND AWAY FROM THE SUN BECAUSE OF THE BREAD COMPONENTS.
I HOPE YOU FIND THIS HELPFUL?
THANK YOU FOR CHOSEN FIXYA.COM
Jun 11, 2018 | Refrigerators
My LG window AC icing on the grid even in fan mode. Once started it gets covered with ice within 1 hours in both cooling as well as fan mode? What can be the reaon
First, I'm not a LG tech.
Check your warranty and call for service.
*** Following is for information only.***
* Check for air movement while fan is running. Many have plastic ducting that pulls air from the bottom that is usually covered by the lower drawer. Pull out the lowest tray and check the back for ice or food that fell in back to block the air vent. If it's iced up, DON'T hit it as you will crack the plastic. Leave the door open, Turn off and let the freezer defrost. (remove food).
* Check the upper fan vent for ice blockage. Defrost as needed.
* Unplug refrigerator to defrost. (Get help to move as the fridge is heavy and may tip over on you.)
* Once completely free of ice (it takes a while. A fan blowing into the freezer helps. ***DONOT use a heater!*** Warps panels and may over pressurize refrigerant.)
* Allow a completed defrosting of the freezer. (Place frozen foods in refrigerator side to keep it cold while the refrigerator is off. Better to transfer everything to another refrigerator.)
* Keep checking and dumping the drain tray as the ice melts. If no water drains then the line may be clogged. Call for service.
* Plug in refrigerator but leave out where you still can unplug it if you need to continue to defrost. Move it back only if everything is working (so far).
* Set the temperature to middle of dial and the freezer diverter to normal (middle). Leave fridge empty to allow it to cool down without a load. Check for icing (there shouldn't be any as there is no moisture in box to ice up.) If there is ice then it did not defrost enough. Turn off and repeat manual defrost (open door)
* Once your sure all the ice is gone and the freezer is cold. Move refrigerator back into the counter/wall. (it's lighter but get help anyway.) Start putting back the frozen goods. Try not to cram in everything. Keep enough space on racks to allow air flow AROUND the whole shelf. Keep away from leaning food against the walls and back.
* Leave the temperature setting at mid range. Your refrigerator should be able to keep food frozen at this setting.
* Check your door seals for cracks
* Check your door perimeter for warmth. It should not be sweating or ice cold. Cool or slightly warm to the touch is normal.
* Check your side panels (not doors). It should be cool but not iced or sweating.
* Final, with the Temperature set at mid range. If your still getting ice then you have a vapor leak. (Moist air getting into the freezer) Note that this moisture can also come from hot moist food placed in freezer without pre-chilling it. If you must put hot food In the freezer. Then place it in the refrigerator section for at least an hour prior to the freezer. The refrigerator can handle the moisture load better than the freezer. The refrigerator just collects the water and drains it to the bottom pan.
* Again, check your warranty and call for service. Have them perform yearly maintenance to check everything.
Aloha, ukeboy57
PS; If everything is okay (so far) then only gradually adjust the temperature SLOWLY. You will find that maxing to the coldest setting will only build up the ice quicker. Normal freezer operation can take care of the occasional (daily) opening of the freezer door. It will 'dry' out the frost and ice build up (If given the chance). But if you find that Ice keeps building then you need a bigger new ice box.
Feb 21, 2018 | LG Refrigerators
My Vissani fridge model HMDR1030 fridge compartment is not cooling. We'd been noticing our drinks weren't cooling for about a wk. The freezer is ice cold with a small amt of soft frost. I rearranged the...
First, I'm not a Vissani tech.
*Check your warranty and call for service.
* I see that you have done most of the following. I'll post the full answer for others to review. You probably need a complete defrost and return the settings to the middle.
*** Complete answer as follows ***
* Keep checking and dumping the drain tray as the ice melts. If no water drains then the line may be clogged. Call for service.?
Aloha, ukeboy57
Feb 20, 2018 | Refrigerators
Why is the refrigerator side is freezing food
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
Nov 01, 2017 | Refrigerators
Freezer not keeping food frozen, now the
Often times when you set a refer at the coldest setting it just does not work
before giving up on it try setting your control at 4 or 5 and see if that helps
Apr 01, 2010 | Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Freezer Does Not Stay Frozen
one of the hardest things to diagnous is food defrosting in the freezer. i found out the hard way about 35 years ago, but not until i banged my head against the wall a few times. the problem was the customer didn't have enough food in the freezer as she was a weekender.frozen food needs frozen food to keep the food frozen confused? so was i . every time your refrigerator goes into defrost( usually every 8 hours) a heating coil comes on in the back of the freezer. if the freezer is not full enough this heater can raise the temperature in the freezer to 40 degrees which will soften the food and melt the ice considering the time it takesto refreeze the food. i never forgot that service in fact i can see it in my head right now.. try this cure first let me know
Feb 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a Whirlpool gb22dk refrigerator freezer. The bottom freezer keeps meat frozen but will not keep sea food ice cream bread ect frozen. This fridge came with our house which we purchased 2 years ago...
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Jun 09, 2008 | Whirlpool Refrigerators
Freezer is not working to optimum capability. Meats and frozen foods harden, but ice cream and breads do not. I have the temperature control to almost maximum. Any ideas?
remove bottom kickplate and clean condensor coils, pull away from wall and vaccuum behind and underneath. if the machine cant breath, it cant cool properly
Mar 05, 2008 | Amana ASD 2624 Side by Side Refrigerator
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
