Question about Panasonic Home Theater System System
Component f61 - Panasonic Home Theater System System
    Genius:
  • Panasonic Master
  • 1,550 Answers
That code means audio amplifier IC damaged and need to bo replaced
Posted on Jul 31, 2010
My panasonic music system (SA VK-960) Is not working properly it shows (F61) error all the components are well attached with music system but there is still F61 error . Help us to resolve this error.
See page 40
Power Supply Error Code Table http://diagramasde.com/diagramas/otros2/panasonic_sa-vk960gc.pdf
Suggest checking power resistors in amp circuits for failed resistor. replace with identical rating in that the power resistors are used in the saftey circuits. Also check around these resistors for failed solder connection.
Hope this helps?
Jun 29, 2017 | Panasonic Audio Players & Recorders
F61 error
I've encountered that kind of problem.
f61 appear on the screen then shuts down the unit.
The very common defect is your fan, output ic (rsn series).
First check the fan if it is in good condition (disassembling the component is quite technical it need a lot of care).
sometimes the fan is full of dirt that's why it will not work properly which the system sense and uttered the unit to switch of avoid further damaged.
If you confirm that the fan is working properly I will suggest you to bring your unit to a qualified technician/service center because replacing the output i.c. is more technical.
Dec 27, 2010 | Panasonic SC-AK340 Shelf System
When turning on F61 shows on the display and will not turn on
People say that it is a fan problem - when it gets stuck with dust or does not work properly the system recognizes it and gets blocked in order to prevent overheating of the components. I changed the fan but the problem with F61 presists despite people say that changing the fan would solve the problem.
Dec 08, 2010 | Panasonic SC-HT70 System
F61 Error message on screen. We can't get the player to even turn on.
Most likly needs an output or voltage IC. Could be other things like a bad fan or other componant. With Panasonic models F61 is a bad voltage code.
Feb 01, 2010 | Panasonic Home Theater System System
F61? how do i fix it...................everytime i turn my panasonic sc-ak340 on i get a error code that reads f61 and then my system shuts down by itself..can this be fixed?
Dec 13, 2009 | Panasonic SC-AK340 Shelf System
F61 code error
Change the audio amplifier IC are damaged that´s the mean of that code
Sep 06, 2009 | Panasonic SC-AK640 Shelf System
F61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
Jun 15, 2008 | Panasonic SC-HT940 System
Panasonic home cinema model sa-ht75 . shows f61 disconnet output ic ,still shows f61
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 26, 2008 | Televison & Video
SHOW ''F61''
This is error code which system control detected either power irrgularities or dc voltage is detected from the speaker out put line.This fault we have noticed that both of them appears same time also.Pls change Amplifier ic TDA8920 and C1740 transistor and 27V1w zener diode.Transistor and zener diode is for voltage regulation and amp ic if the dc detect is active.Usualy change this three components same time.(this all is in power amp section)
Dec 17, 2007 | Panasonic SC-AK340 Shelf System
My Panasonic SC-A240 shuts down displaying the error f61.
Several components in the power supply maybe faulty, especially Tranisitor Q5110, Resistor R5114 and Diode D5102 on the power supply board. Check and replace these and also resolder the regulator IC's on the heatsink.
Sep 05, 2007 | Panasonic SC-AK240S Shelf System
Panasonic Home Theater System System Logo
235 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
