Question about Sony Car Audio & Video
Where can i find the reset button for my sony
Where can i find the reset button for my sony cdx-gt07?
smarthome2
  • 1114 Answers
SOURCE: Sony cdx m610 resets itself at half volume
You have a shorted speaker or speaker wire. If a wire is touching metal lightly it may not have full continuity (short) and will work until more voltage (volume) is sent to the speaker and causes the short. Disconnect all speakers at the radio then turn the unit back on. Turn up the volume and see if it cuts out. If it stays on, re-connect speakers one at a time and test. Once you find the problem speaker, disconnect the wire at the speaker then test again. This will eliminate the speaker itself as the problem. Test again. If it still shorts, trace the wire from dash to speaker and look for a cut in the sheathing exposing the wire. Repair or replace the wire and you should be good to go. If the unit cuts out with all speakers disconnected, the problem is internal and will need to be serviced. Before you repair/ or replace the unit either check all the wiring and the speakers or have someone do it for you so it does not give you a repeat performance. Hope this helps.
Posted on Oct 01, 2009
  • 1126 Answers
SOURCE: I need to buy a replacement wiring harness for my
Here is a link to Sony for parts available for your CDX-GT07. Though I don't see a harness as an option here.
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&searchText=CDXGT07
Sony head units normally have either a 9 pin or a 16 pin harness. Here are both links respectfully.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C285614
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C217600
Posted on Nov 06, 2009
  • 1126 Answers
SOURCE: need to know the speaker wiring code from the back
This is a link to Sony for your CDX-GT07 wiring color codes.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C217600&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=151784013&stateId=0 0 151782618
Posted on Dec 03, 2009
Testimonial: "i want to thank you all for your help. you gave what the sony web site would not help me with. "
  • 27 Answers
SOURCE: cdx-gt07 just stopped working
try the fuse box, fuse might have tripped
Posted on Jan 29, 2010
  • 30 Answers
SOURCE: i have a problem
Check the Wiring, sounds like there may be a crossed wire or possibly a short.
Posted on Nov 04, 2010
Can I hook a amp to this model cdx-gt07
This model does not have rca outputs on rear. To wire a sub to it you will need a signal processor. You wire speaker lead to box and it will covert signal to an rca output for amp.
Sep 15, 2015 | Car Audio & Video
Sony CDX-GT210 Can't find the reset button. Radio plays fine, but No sound comes out when I use CD player. Panel displays that it is able to read disk (numbers for time played goes up and displays...
Usually Reset button located underneath front panel, remove front panel and look at unit, hopefully you will see reset button, press it with some pointed thing like paper clip etc to reset the unit.
Thanks.
Aug 11, 2011 | Sony CDX-GT210 CD Player
I was given a cdx-gt07 sony fm/am compact disc player and i need a wiring diagram to install the radio. where would i get one. joeturtle
had a search around and found a manual for you to download:
www.retrevo.com/support/Sony-CDX-GT07-Car-Receivers-manual/id/16768bh031/t/2/
Mar 15, 2010 | Car Audio & Video
It seems like it is in demo mode, buttons don't do anything, it just keeps saying what it has. ie sony, mp3, cd, eq presets... etc.
ı have this problm too ,how can we fix this problem and i couldn't find the reset button of cdx-r3300 s- mosfet..in its manual somewhere is defined but in my equipment there doesn't exist a reset button :((( heeeelp...
Dec 12, 2009 | Sony CDX-R3300 CD Player
Installing a sony cdx-gt07 cd player in a 2000 dodge
In the mix of wires there will be a constant wire. this is usually labeled on the back of your deck this is the wire that need to be hooked into the hot wire. this will provide constant power to the radio that will help it keep the time,position on cd when powered off and other info.
if you need anymore help just give me a shout
Mar 25, 2009 | 2000 Dodge Ram 1500 Truck
Black out
this is a coincedence. The CDX-M800 had a HUGE problem with the ribbon cable on the face going bad, causing this exact problem.
$14.00 and some time will put it back into perfect condition.
http://cgi.ebay.com/ebaymotors/Fix-your-Sony-CDX-M800-flexible-ribbon-cable-CDX-M800_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ43947QQihZ020QQitemZ300287945333QQrdZ1QQsspagenameZWD1V#ht_2258wt_1213
Jan 21, 2009 | Sony CDX-M800 CD Player
Car Audio & Video Logo
59 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
