Question about Tunturi T30 Programmable Treadmill
Tunturi 620 treadmill has error code 51
I tried turning it off and on, unplugged form the wall. It still won't start
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: My Tunturi Treadmill ramp is stuck in the top
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Posted on Jun 14, 2010
SOURCE: tunturi j 661 f treadmill won't start.says E1.
Treadmill wont start-up
Posted on Jul 20, 2011
AJIN G
  • 6694 Answers
SOURCE: Tunturi treadmill displays 51
hi,
Do on thing press and hold the reset button for 4 to 5 seconds.
IF doesn't help then watch which display shows the error 51. Press and hold the corresponding (display) button and press the reset button and hold the two button pressed for 3 seconds.
ok
Posted on Aug 19, 2011
  • 95 Answers
SOURCE: Supplier for a Tunturi T85 treadmill circuit board?
Here is a parts list for the Tunturi T85 with many available parts. I don't see a circuit board but you may be able to contact the company to see if it has a different name or if they can get it added.
Posted on Sep 18, 2012
My tunturi 620p has a e2 code how can i fix it
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. check for tunturi treadmill articles
http://electro-medical.blogspot.com/
Feb 23, 2016 | Tunturi Exercise & Fitness
Have a J620P and just received a 51 code. What is it, and how do you fix it?
Follow the next step:
Scan by 3 seconds for to clear the error the display and restart the treadmill
If the error Do not appear,continue.Electrical fluctuation can be have actuated in the system electric power, and cause the display error.
If the problem persist call:206-881-7392 tunturi treadmill
God bless you
Oct 01, 2013 | Tunturi Exercise & Fitness
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
My tanturi treadmill model j620p indicate 51 in the panel. even i press the reset button still the 51 still in there. all keys does not work too. what shoul i do?
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING
THE RUNNING DECK
Please apply teflon by using the pressurised can provided
with these instructions.
1. Let the treadmill run at a slow speed and spray
teflon into the lubrication .
2. When teflon is applied for the first time,
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 23, 2011 | Exercise & Fitness
When walking on my pro form xp weight loss 620, while walking along fine, every so often it starts to make a slipping sound and seems like the belt is slipping. tried tightening the belt and still does the...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jul 07, 2010 | Proform XP Weight Loss 620 Treadmill
I have a Tunturi j770 treadmill with error code E1. What does this mean please?
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
May 17, 2010 | Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
My Tunturi J620P stops and E-1 shows in display
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the powerswitch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
May 14, 2010 | Exercise & Fitness
TUNTURI 620p TREADMILL displays 51, or S1 WHEN TURNED ON , AND WILL NOT OPERATE. PLEASE SEND ANY INFORMATION TO HELP SOLVE THIS PROBLEM.
Solution:
press and HOLD the button that says display above it and Reset below it untill you see the normal start up Screen and yoru good to go!
Feb 17, 2009 | Exercise & Fitness
Tunturi T30 Programmable Treadmill Logo
310 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Marvin
Marvin
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
