Question about Samsung LN-R328W 32 in. HD-Ready LCD Television
There appear fixed vertical/horizontal noises on samsung lnr 328w lcd tv. When appeared, all images are shown behind the fixed noises. I read about the solution http://www.fixya.com/support/t368621-screen_noise and replaced the T-Con board. The problem persists. I checked the integrity of the cable connection the t-con and the logic board. It turned out fine. Do you guys have any solutions?
  • terrybeyond Jul 31, 2010
    thanks. i'll look into it
  • 10,594 Answers
If T-Con board replacement did not solved the issue then it is lcd panel that will be replaced.
I'm afraid, there is no other solution for that problem. LCD Panel need to be replaced and it would cost you 80% of tv price.
Thanks.
Posted on Jul 31, 2010
    Can it be the logic board? since the signal comes from there and if the noise interference happens there it affects the rest of the connection?
  • Shahid Electronics
    Shahid Electronics Jul 31, 2010
    As you said that image is seen behind the noise, that means this noise is not coming from logic board/ main board and it is lcd panel own problem that appears over image.
    Image data comes in T-Con board that slice it and send to lc panel that again it slice more to drive each lcd pixel to create an image. If you observe any damaged lcd panel, you will find circuit board strips on top and side of lcd panel to drive lcd pixels. These boards are part of lcd panel and can not be replaced.
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | Toshiba Televison & Video
Samsung LNR 328W
Power supply failure
Nov 06, 2017 | Samsung Televison & Video
Vertical lines have appeared on my LN46B640 LCD TV When I turn it on, the picture is clear at first, and then over a couple of minutes vertical (predominately yellow) lines appear over the image.
if this tv is under warranty i would call samsung, there could be three board that could be going out on it one is the techon board, main board, but you also my need the ip board changed out to. i repair samsung all day long and i see this problem a bit.
Oct 12, 2009 | Samsung LN46B640 LCD TV
Samsung LNR 328W TV turns itself off and turns itself back on
it sound to me like your power supplie is heating up and shuting down your power supplie is on its way out
Dec 02, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Screen Noise
Hello LNR328W
You have a bad T-con board. This board is mounted directly on the panel. Its located near the top of the set in the middle. This part is sold with the panel which makes it expensive. I have a few T-con board in stock. Let me know
Best regards
circuitcity
Jan 24, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
LNR-328W
90% of the time this is caused by a bad LCD panel. The other 10% is caused by a bad Main board. You may want to try and change the main board first. This set carries 2 different type of main board. You MUST look at your Version Number located on the side of the unit. (Version AM02 uses BN94-00667S.Cost $177.81) (Version 0001 uses BN94-00629R.Cost $176.14) LCD pane BN07-00194A Cost $806.49
Best regards
CircuitCity
Dec 03, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
48 people viewed this question
Jerry Greenberg
Jerry Greenberg
