Question about Brother MFC-3240C All-In-One InkJet Printer
NO CARTRIDGE MESSAGE DCP-34OCW - Brother MFC-3240C All-In-One InkJet Printer
  • gkbernhardt Dec 06, 2008
    One of the cartridges is showing as "no cartridge." Reinstalling it is not solving the problem.
    Problem Solver:
  • 7 Answers
Recycle the pwer to see which cart is empty and needs to be repalced
Posted on May 16, 2008
My brother DCP 7055 shows eror replace toner
Some Brother laser printers have separate consumables - the toner cartridge and the drum unit. From time to time you may need to replace only the drum unit and not the toner cartridge.
The error LED lights up, or an error message shows on a flat screen panel, when the drum unit is near the end of its working life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
Jul 26, 2012 | Brother 1 Black Genuine Laser Toner For...
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Jan 04, 2010 | Brother DCP-7040 Laser Printer
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
"No cartridge" message even with new cartridge
It seems more like the sensor is wrong because the message is not "empty cartdrige" (or something like that), it says you have no cartridge in the printer.
With our working phisically in your computer, I recommend you to take the ink cartridge off, and then look closely for something broke, it should be something physical that notify the printer when there is something pluged in.
Sometimes the sensor is electronic, in that case unless you have electronic knowledge I recommend you to take it to a printers shop.
And sometimes, it is cheaper to buy a new printer than to fix it.
good luck
Apr 19, 2009 | Brother DCP-7020 All-In-One Laser Printer
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
get those here
Aug 19, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
46 people viewed this question
James Cagle
James Cagle
Jim Keysor
