Question about Homelite Garden
Rotted fuel lines
My model HLT-16. the fuel lines are rotted. do the both have to long enough to be in the tank all the way?
    Sergeant:
  • 170 Answers
Normally one fuel line has a small filter on the end of it. that one needs to be exactly the same size. that one sucks up the gas and sends it to the engine. the other fuel line is for the excess gas / air to return to the gas tank and keeps it from spilling all over you / or wasting fuel. it can be shorter but is required to be inside the gas tank to recycle the unused fuel
Posted on Jul 31, 2010
How do you replace fuel lines on a craftsman 16" chainsaw model#358.352161?
remove the carb and then pull fuel lines from tank ,there should be a filter in tank attached to the fuel line you will put that on the new line then feed it through from in the tank out
Oct 30, 2014 | Craftsman Garden
How to change fuel line on craftsman blower
Before you start take a picture of where the old lines are connected to the carb and the primer bulb for future reference.
To replace the line pull the spark plug wire from the plug. Remove the old line from the tank and remove the fuel filter from the line. Take new larger line and cut it on a 45 degree angle/or trim as necessary so you can grip it from inside the tank and pull it into the tank. Perform the same operation on the smaller line as well. Be sure to leave enough line for the fuel filter to reach the bottom of the tank. Install the fuel filter. The other small line is a vent line and only needs to come inside the tank not go to the bottom in the fuel.
Good luck.
Jun 07, 2014 | Craftsman 4 Cycle Blower/Vac
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
FUEL FILTER
(For 40/55/60/70/110/115/155/165 Models
Only)
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Fuel line in tank dry rotted how do you replace
Hi classic11369...
Remove the old fuel line and filter from the tank...
You will insert a wire a little smaller than the diameter of the inside of the fuel line, and you will bend a small hook on the end of the line to fit over the fuel line (be sure to use a small wire) .
Lubricate the first 1 inch of fuel line with vasoline lightly...using your fingers or neednose pliers collapse the fuel line and insert it into the fuel tank, entend the fuel line long enought to go out of the fuel tank so you can reconnect the fuel filter...then pull some of the fuel line back into the fuel tank...
Please take time to rate me thumbs up
Sep 23, 2011 | Homelite ZR10926 16" Chain Saw
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a 1994 Gran Marquis. Fuel lines are rotting and leaking
Just get a piece of the rotting fuel line so that you will be assured of getting the right size. Take it to a shop that sells car accessories, and ask them for enough to do your car. Also get new clamps. Start at the fuel tank, undo the clamp, pull off the old hose , put on the new one, do up the new clamp, and then just follow the old hose along, replacing it with the new one as you go. At the far end. do the same... undo the old clamp, put the new hose and clamp on. But I forgot to tell you about the fuel filter. Replace this while you are doing this job.
Feb 23, 2010 | 1994 Mercury Grand Marquis
How to know were the fuel line runs on a mcculloch 2014 chain saw
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Nov 30, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
No full speed then dies
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 23, 2009 | Craftsman 4 Cycle Blower/Vac
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Garden Logo
124 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
