Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Machine will not produce steam. Machine will heat up but not enough to produce steam. Help ...
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
;a
Posted on Sep 24, 2010
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
My shark steamer is foaming and no steam is coming out
You cant put soap in the steamers, only water. Clean out water container and start new. Also, clean hole where steam comes out with something thin. Make sure it is heating up enough to produce steam, otherwise heat assembly is broken.
Mar 08, 2017 | Shark Vacuums
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
Steam mop is not working, even after replacing the filter. Only used three times.
Rejoice with me! I called the helpline and they told me to unplug, then stick a needle into the hole on the bottom where the steam comes through. I did that, then plugged in and turned on the steam. Black liquid came out and a little steam came out. I shut off the machine, unplugged and used the needle again. This time, a geyser of steam went up into the air from the machine! It was clogged and just needed a couple of pokes. I put the steam plate back on and just cleaned my kitchen!
Jan 26, 2014 | Oreck VersaVac Bagless Vacuum / Steam Mop
Hi - I have an Ocean Sales, Inc. steam mop, model #7603 that I have loved using. It has now stopped producing steam. I can't find my manual. Can this be fixed, or is it time for the trash can? ...
There is a heating element in there that gets hot and produces steam. Obviously it is not getting power or it has burned out. If it is the latter you need to find out how much the repair part, if available, costs. The expense and hassle might just not be worth it.
Jul 23, 2011 | Vacuums
My shark steam mop will not heat up and produce steam. it has only been used 4 times. help
Empty the water and try different water...
heatman101
Jan 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Cleaner heats up but no steam is coming out. It let loose a big ball of steam when I plugged it in, then nothing and still won't heat up enough to produce steam.
heatman101
nt
Nov 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My mini steam zapper heats but produces no heat
you should get steam in the amount of time it take to boil water
Feb 18, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
Turns on but won't produce steam
heatman101
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
351 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
