Question about Sharp AR-M207 All-In-One Laser Printer
Scanner resolution People who I send scanned files to often tell me that they are very light. How set the default resolution to be darker?
  • 94 Answers
Resolution is scan density x dpi; dot per inch. contrast is the control that you seem to be looking for.
Tip: before you send them, look at what you have.
Posted on Jul 18, 2008
Scanner keeps scanning 81/2 x 11 paper and saving as 81/2 x 14
The scanner driver is probably set to save as 8.5" x 14" as the default. Open the Lexmark scanner utility or driver properties and look for the default scan settings. (These will include file type, resolution, and scanned image dimensions, among other settings.)
If you see that the current default setting is 8.5" x 14" (or "legal") you can change it to 8.5" x 11" (or Letter), or if there is an option for automatically detecting size based on the original's size, you can do that as well. Click OK or Apply to save your changes.
May 20, 2010 | Lexmark P4350 All-In-One InkJet Printer
How to adjust the resolution to 300 DPI on an
If you are scanning, you should be able to set the resolution (DPI x DPI) in the scanner configuration. If it is blurry, it could be that the default scan resolution is lower (10 dpi or even 75 dpi).
Settings location will depend on the scanner and software used.
Best scan at an equal (300 dpi) or even higher resolution, so you can scale the image afterwards without quality loss.
Apr 23, 2010 | Microsoft Windows XP Home Edition
I want to increase the size of the small drawings i do from my epson 1250 scanner to my canon 1800ip to a4 printout size is this possible.
You have to scan the pictures with a higher resolution to be able to print them in a larger format with acceptable quality.
If your default scanning setting is, say, 150dpi resolution, and you want the picture to be enlarged twofold, then you have to increase the resolution to 300dpi. If you have 300dpi now, increase it to 600dpi.
Some scanner utilities do a fully automatic scan - then you have to find the automatic scan settings and change the default resolution. Or better yet, find an option for a non-automatic scan, where you are presented with various options after the preview scan has been done. There you can usually set the desired size, resolution, improve contrast, sharpness etc.
Generally, the higher the scanning resolution, the more detail you have on the picture, and the higher magnification you can obtain when printing without quality loss.
But there's a catch - a picture in higher resolution produces a bigger file on disk - the file size grows faster then the resolution - a two times bigger picture will be four times bigger on disk. So you have to make sensible choice.
Nov 06, 2009 | Canon Office Equipment & Supplies
MY RICOH 2020D PRINTER, IS VERY SLOW AND IT DOES NOT SCANNED AT 20PPM, PLUS THE FAX MEMORY ONLY HOLDS UP 40 PAGES, WHAT CAN I DO?
You must have your resolutions set much higher than the default.
Scanner: Go to "user tools", "Scanner features", "scan Settings", "default Scan settings", "resolution".....set to 200dpi
Fax: Resolution may be set to "detail" or "fine" by default , rather than "Standard" ...is either light lit?
This would dramatically reduce memory capacity.
To set this to default standard resolution is a needlessly difficult task. You can either manually turn it off when sending a fax or change the default "user parameter settings" for the "home position". You can find instructions in the Fax manual (Advanced settings). Download here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/x2016_20/x2016_20en.htm
How to set parameters and understand them (sort of ) is on page 80
How to set home position is on page 86
Mar 09, 2009 | Ricoh Office Equipment & Supplies
I have bizhub c350, everytime i scan to email i get multiple emails each with 1 page. how do i fix this?
If you go into the admin setting when using the web browser you can enter the email setting one of the options is binary, if you turn off or on depending on the setting it should stop this fault.
Mar 02, 2009 | Minolta C350 Color Printer/Scanner/Copier
Ricoh Aficio 2027 when scanning documents over 4 or 5 pages e-mail documents with no attachments, and pages of gibberish in the body of the e-mail. How do I fix this?
Try increasing the "max email size" -or turning it off all together.
I'm going by my own memory, so, you may have to do some browsing of settings, but I believe the setting is under: "User tools", "Scanner features", "send settings", (or some similar button under scanner features). There you should see a setting for Max. email size (or similar). The default is 2048kb.....try increasing it to whatever you want- maybe 4000-5000kb, and check the results.
Usually the machine will stop scanning when it reaches the max size, so I'm not sure if this is the problem, or if we are talking about very large files that actually exceed your emails capacity to allow an email of this size? How large are these files once scanned that you are talking about? What is your scanner's resolution set at? 200dpi is more than sufficient for text. You can check that at the same location as above only select "scan settings", "default settings". If resolution is set to 400 or 600 dpi the files will become MUCH larger than they need to be.
Hope this helps.
Feb 22, 2009 | Ricoh Aficio 2027 Black and White Copier
Scannning too slowly
Increasing the default resolution setting, would slow the scanner down, and also increase file sizes dramatically
Feb 18, 2009 | Ricoh IS760D Flatbed Scanner
Default Scan Resolution on Canon iR C3220
imm assumiing your using the send feature to scan to sett it up different ways in this order add functions communication settings this should bring up a screen with left and right colomns.. the left one should have a tx setting touch that and scroll till you find custom send settimgs
Nov 25, 2008 | Office Equipment & Supplies
Text being scanned does not produce a clear print to our cannon ip18oo printer
alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
Aug 13, 2008 | HP Office Equipment & Supplies
We need to set the default resoultion on our Canon IR 3170C printer as it is set at the highest setting which creates massive file sizes. We can set it up at each individual scan to a lower resolution but...
try to set from Start-> Control Panel-> Scanners -> Properties.
Then set the values and select ok/Apply to save the value.
  • Pleae close if any window open for scan before making the above changes.
Post your feed-back.
Thanks
Iqbal
May 06, 2008 | Office Equipment & Supplies
Sharp AR-M207 All-In-One Laser Printer Logo
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
