Question about LG WM-2277HW Front Load Washer
Fabric softener dispenser filling with water after wash load
zeusfaber
  • 247 Answers
SOURCE: Bleach and fabric softener dispensers full of water
This is a problem common to virtually all front-loaders. Pull the dispenser drawer right out (it is designed to come right out - you might just need to give it a bit of a jiggle to get it past the stop) Remove the cover/caps from the drawer (sometimes this is a snap-on cover over the back of the drawer, sometimes a top-hat shaped cover over the siphon spigots). Give everything a thorough clean off with hot water (scrubbing with an old toothbrush helps), then reassemble. A.
Posted on Jul 16, 2007
  • 489 Answers
SOURCE: Fabric Softener & bleach dispensing
The control board program has many sensors built into the unit to determine when to dispense the bleach and the softener.  LG tech documents doesn't list when these liquids are dispensed so there must be a program that matches the current operation and loads of each wash program.  That's the best answer I can give you at this time.
Posted on Jun 11, 2008
  • 60 Answers
SOURCE: water fills dispensers
A small amount of water left in them is normal but if they are totally filled something is wrong. Do you still have the blue pieces in the bleach and softner cups? If they're missing they will not empty right. You may also have build up in the holes that the liquid should go down that you may have to clean out.
Posted on Aug 15, 2008
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
SOURCE: the softener dispenser is not putting the softener
I have the exact same problem. I hope that someone can help us out!
Posted on May 11, 2010
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
How do I get the fabric softener dispenser to keep from filling with water?
Remove dispenser and clean the drain hole from under neath try with q tip.sounds gunked up.
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
Fabric softener dispenser will not empty
Hello Mike Oswald - Fabric Softener is a very thick liquid that can clog up the siphoning mechanism. Try the following steps below.
  1. Remove the Dispenser
  2. Remove the Inset in the dispenser
  3. Clean out the dispenser and dispenser cover
The Fabric dispenser needs to have the hot and cold water at equal pressure for the fabric softener dispenser to operate properly.
1. Turn on the hot water fill then cold water fill at the washer. If the Wash Sense or temperature sensing is on it needs to be off.
  • If they seem to fill at the same pressure then you will need to contact a professioanl to move forward accurately.
  • If they seem not to fill at the same then you need to correct the pressure.
Mar 03, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
Jun 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
LG WM-2277HW Front Load Washer Logo
186 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
