Question about Kwikset 907 907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt
I recently changed the batteries on my Kwikset 907 and now the "lock" button UNlocks and the entry code engages the deadbolt. I have removed the batteries for 5 minutes, but did not that did not reset. Have also tried to enter a different code and that did not correct the problem. Can you help?
Mines is unlocking by it self and still beeping
Posted on Aug 25, 2010
Kwikset smartcode deadbolt newly installed unlocks when lock button pushed. I have taken batteries out and reset few times with no success.
"I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?"
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
These instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
These locks are made to work on a door which, when you stand outside and face it, has its hinges on either the left-hand or right-hand side of the door (= door "handedness").
The jumper controls that for the appropriate installation. Yours is set wrong!
Jul 10, 2012 | Kwikset 907 907-11P Venetian Bronze Smart...
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How do I change the code on a Kwikset key pad
Here you go....
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
pb1000programbutton
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
Aug 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I'm using a kwikset smartcode lock. When I follow the directions, holding the lock button while inserting the battery pack, instead of two beeps after a while, I get a beep, then 5 seconds later a long...
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Apr 26, 2011 | Kwikset 907 907-11P Venetian Bronze Smart...
My Kwikset Electronic Deadbolt is working in reverse. When I push the lock button it retracts the deadbolt. When I put in the access code it extends the deadbolt. What is wrong?
My lock did not have jumpers, but adjusts itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Mar 05, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Do you know how to reprogram digital code?? kwikset 907 lock
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ...
2) Make sure all batteries are fully secured.
3) Press the square Reprogram button
4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured.
5) After entering your code, press the middle keypad (lock) once.
6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
Jan 06, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Why doesn't the back lights work on my Kwikset 907 Power 1000 Keyless Entry Deadbolt? Are there any other batteries beside the four 1.5 alkaline batteries?
Installation instructions for the Kwikset 907 link:
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
This is the link to Weiser Customer Support Page, where you will find the appropriate number for your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
Oct 21, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
How do I reset the code? I just moved into a house that has one but no instruction manual.
On the inside under the back plate you will find a button on the bottom left. Press button once enter you code 4-8 digits. Then press lock. Re-enter the code. If it unlocks you code is entered. This unite can keep two codes. To set the second code hit the back program button twice and follow the above directions. Also not the key lock is a Smartkey sysyem so you can change the key also.
Nov 16, 2009 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Kwikset 907  907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt Logo
320 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
