Question about Amcor Heating & Cooling
I have an amcor cf14000e unit that is not cooling down.
I have an amcor cf14000e unit. why does it not cool down to the temperature I put it out. for example if it's 90 degrees outside and I set it at 65, it will not go below 70. And it takes approx 4 hrs for it to even cool down from 80 to 70 degrees in a regular size room with the door shut. The water tank is empty. I have only had the unit for 2 yrs. How long does a compressor normally last?
Joe_Rex
  • 114 Answers
SOURCE: Water is not dripping from window A/C unit, air is cold but damp
HELLO .. HOPEFULLY YOUR UNIT SLIDES OUT OF THE A/C HOUSING, IF IT DOES REMOVE IT. (THERE MAY BE A FEW SCREWS HOLDING IT IN PLACE USUALLY BEHIND THE FRONT GRILL) PUT DOWN SOME OLD RUGS FIRST AND HAVE SOMEONE HELP YOU SLIDE IT OUT. GET OT THE GARDEN HOSE AND SPRAY NOZZLE. PROP UP THE FRONT OF THE UNIT SO IT DRAINS TO THE REAR. BOTH THE EVAPORATOR COIL AND CONDENSER COILS SHOULD BE CLEAN. YOU WILL NOT SEE DIRT ON THE OUT-SIDE OF THE COIL ... IT WILL BE ON THE INSIDE HIDDEN BY THE CONDENSER FAN BLADE. BE VERY CAREFUL NOT TO BEND THE FAN BLADE WHILE INSPECTING OR WASHING. BE EXTREAMLY CAREFUL TO COVER THE MOTOR AND ELECTRICAL CONTROL BOX WITH PLASTIC BAGS TO ENSURE ALL ELECTRICAL COMPONENTS STAY DRY. FACTOID: 90% OF AIR CONDITIONERS THAT "DONT COOL AS WELL ANYMORE" IS DUE TO DIRTY COILS. THERE IS ALSO A TUBE OR CHANEL THAT DRAINS THE WATER FROM THE EVAP (FRONT) COIL TO THE BACK OF THE UNIT. THAT CONDENSATE WATER IS SUPPOSED TO ACCUMILATE IN A SNALL RESEVOIUR WHERE THE SLINGER RING ON THE OUT SIDE COIL FAN BLADE PICKS IT UP AND HELPS COOL THE HOT CONDENSER COIL. SOME OLDER UNITS MAY NOT HAVE A SLINGER RING AROUND THE OUTSIDE OF THE BLADE. NOW ... MAKE SURE YOUR OUTSIDE FAN BLADE IS CLEAN. AS WELL AS THE INSIDE BLOWER FINS ON THE "SQUIREL CAGE". NOW THAT YOUR UNIT IS CLEAN AND YOU CAN SEE CLEARLY THROUGH BOYH COILS, GO AHEAD AND OIL YOUR MOTOR. CHECK TO SEE IF YOUR FAN MOTOR HAS "OIL CAPS" USUALLY THEY ARE AT THE TOP OF THE 2 ENDS OF THE MOTOR. IF THERE ARE CAPS REMOVE THEM AND USE A STRAIGHT WEIGHT (NON-DETERGENT OIL). SOME WINDOW A/C'S UNDER 12,000 BTU'S ARE SEALED UNITS. IN THAT CASE YOU WILL HAVE TO REMOVE THE UNIT FROM THE WINDOW MOUNTING BRACKET. AND FOLLOW THE SAME PROCEEDURE AS LISTED ABOVE. GOOD LUCK AND STAY DRY.
Posted on Jun 25, 2007
hotuna
  • 288 Answers
SOURCE: Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Posted on Dec 04, 2007
SOURCE: room temperature has not changed since hooking up new portable a/c
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
sloooo44
  • 235 Answers
SOURCE: I have a Nanomax Amcor CF14000E and for some
It sounds like your sensor failed. You'll need to disassemable the unit to find and replace the sensor. Chances are it's just a 100 OHM sensor and it cost about 10 bucks to replace. Do you have the manual and does it have a schamatic?
Posted on May 12, 2010
Testimonial: "sLOOO44 i have the manual but no schematic"
  • 22 Answers
SOURCE: I HAVE AN AMCOR MODEL
If your filter is dirty you need to clean it or change it. Also check the condenser it might also be dirty and needs cleaning. When was the last time you changed your filter?
Posted on Jul 20, 2011
Amcor amb 12000e, starts to cool and after a few minutes the unit "shudders" and starts to heat. Not sure why, please advise. Thank you
You are almost out of freon... call a service co... DO NOT run this unit until you get it charged.
Jun 19, 2017 | Amcor Heating & Cooling
Need a service manual (not a user's manual) for Amcor CF14000E
THEY WENT BELLY UP TWO YEARS AGO.WwHAT TYPE OF INFORMATION ARE YOU LOOKING FOR ?
Aug 26, 2011 | Amcor Heating & Cooling
I HAVE AN AMCOR MODEL MF8000E AND IT DOSNT COOL BELOW 70 AND I SET THE TEMPERATURE TO COOL @ 65 WHY? THE FILTERS ARE DIRTY
Jul 20, 2011 | Amcor MF8000E Air Conditioner
Air is not coming out cool what should it be set on?
It should be set to a temperature that is at least a couple degrees colder than the area you are trying to cool. Is this a newer unit or is it older. Have you had problems before, or is this a new issue?
Sep 28, 2010 | Amcor PLM-14000E Portable Air Conditioner
I have a Nanomax Amcor CF14000E and for some reason, when i have it running, after i set the temperature to say 73deg F the digital screen then goes back up to 90 deg F, This is not the room temperature...
May 11, 2010 | Amcor PLM-14000E Portable Air Conditioner
Does not seem to cooling very well
clean both the evap coil and the condensor coil
Jul 13, 2009 | Amcor NanoMax A12000E Portable Air...
Amcor 12000-E air conditioner will not emit cold air. all filters are clear and hose is vented to outside. I'm about to boil
Hi, I'm new here but have the same model. Is your A/C new? Is your "Mode" set to "Cool" rather than "Fan"? Is the temperature set below room temperature? If not it will just run as fan. Lastly is your water reservoir full? Probably not the problem as the unit will shut off. Looks like you posted this a couple weeks ago, hope you figured it out.
Tim
May 07, 2009 | Amcor ALTL-12000E Portable Air Conditioner
Heating & Cooling Logo
140 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
