Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
Why is my malibu 200 watts transformer not working, the timer will set off the lights but then not turn them off, then the next day they wont come on but when I rotate the dial they come on? Frank
Tripper might be worn down and not pushing switch.
Switch might be broken or worn down.
Improvise by setting timer to override and plug power into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Mar 21, 2011
Dusk to dawn sensor for 24 v light system
Malibu transformer is 12 volt AC
They make a photo eye for ML300-600-900 watt units, but not for 75-100 watt units
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 04, 2013 | Malibu ML200RT - Low Voltage Power Pack...
Does Malibu still make a model number ML500TW timer transformer
Intermatic/ Malibu series lights are available 44 watt, 88 watt, 100 watt, 121 watt, 200 watt, 300 watt, 600 watt, 900 watt.
None of the other brands sells 500 watt either.
Kichler sells 300 and 600 and 900Watts
Paradise does not have 500 watt
Malibu brand does not carry 500 watt
Portfolio does not carry 500 watt
Apr 16, 2013 | Hardware & Accessories
MALIBU 200 WATT IRON CORE TRANSFORMER MODEL NO 8100-0200-01 LIGHTS WONT TURN OFF
Plug power pack into cheap wall timer, and that will operate lights until warranty is resolved with Malibu or product-seller.
Simple power outage, or nearby lightning strike, can cause surge that will knock out digital timers. And knock out analog series power packs too.
You probably need receipt for warranty claim.
This timer is not shown on Intermatic site, and not subject to Intermatic 5-year warranty, but certainly Malibu must have a warranty of unknown length, and a corresponding claim procedure.
Double-check your installation, and additional resources:
Whole-house surge protection is hot item among folks these days since so many household items are now electronic, including appliances, washer-dryer, water heaters, timers, etc.
This will protect both 120Volt and 240Volt circuits, although it is unknown if your timer failed because of surge..
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Sep 29, 2012 | Hardware & Accessories
Lighting transformer and wiring
Open following link for ML200 and other models of low-voltage transformer timers, for instructions, wiring, tips and troubleshoot:
Jun 22, 2012 | Malibu ML200RT - Low Voltage Power Pack...
My Malibu ML 300 RTW has stopped working, but I can hear the timer. No lights come on, though.
Sounds like the transformer died which isn't uncommon. One cause is overloading the circuit (too many lights) figure out the total wattage by adding the bulb watttage usually 11 by the amount of lights you have. I would buy a transformer with around 200 Watts higher than you need to allow for expansion and the transformer wont have to "work" as hard.
Aug 28, 2011 | Intermatic Malibu 300W Power Pack...
I put in a new 200 w Malibu LV. It worked one day, then only one light would work. The next day it worked again on all lights then it went back to lighting only one. I'm using a combination of 12 LV...
I don't have repair for defective transformer.
The transformer puts power on the wire. Buy multimeter and check voltage across the terminals.
If wires are loose, or bulbs are not connected to wire, or bulbs burned out, or if wattage of bulbs is mis-matched with transformer wattage, then lights might not work as expected.
Aug 16, 2011 | Intermatic & Malibu& 300 Watt Power/Pack...
I need instructions for setting the timer
Malibu product manuals
http://www.malibulights.com/customer_service/owners_manuals.aspx
Manual for 300 Watt power pack
http://malibulights.com/docs/pdf/8100-9300-01.pdf
Read cautions
Tips
300 Watt power pack requires sum of bulbs to equal 300 Watts
If you use 10 - 20 watt bulbs that is only 200 Watts so you need 200 Watt power pack
Replace burnt out bulbs immediately or other bulbs will burn out and shorten life of power pack
When working on bulbs, unplug power pack so it does not shorten life of power pack
Set Malibu Timer:
Red trippers are ON
Black trippers are OFF
Place trippers on dial at ON OFF times/ AM and PM
Set current time of day:
Plug in power pack
Trippers are installed
Rotate dial counter-clockwise to current time, say 9 am
Rotate dial 2 more revolutions and then return to current time
That's it
Oct 12, 2010 | Intermatic Malibu 300W Power Pack...
Timer worked for years. Just replaced lights. There were (8) but now there are (10). I didn't do the work and didn't know the wattage (and am not positive, but this looks like the unit). The lights work,...
Download manual for Malibu 200 Watt power pack
According to Malibu website information, your power pack is correct size if lights come on.
The way to figure is this
10 bulbs x 18 watts each = 180 Watts
so 200 watt power pack is good
Does the manual override work?
Rotate the on-off button counterclockwise
If override does not turn lights on-and-off, then timer has a short
Does the center dial turn when power is on?
If the dial is not turning, then power pack is kaput, or time of day is not set
Did you reset the time of day?
How to set time of day:
Put your trippers in place
Red = ON
Black = OFF
Plug in power pack
Rotate arrow (colored blue in diagram) as follows
Turn dial clockwise to present time of day (diagram shows 9 o'clock)
Turn dial one or more full revolutions, then return to present time of day
If center dial is still not rotating after setting time of day, it's time for new $50-80 power pack, unless you put a $15 timer on that plug. A cheap timer might work ... keep it going for couple more years.
Oct 08, 2010 | Malibu ML200RTW - Low Voltage Power Pack...
Transformer problem
Malibu power pack has to match total watts of bulbs
15 bulbs each 20 watt = 300 Watt power pack
10 bulbs each 20 watt = 200 Watt power pack
Mar 01, 2010 | Malibu ML200RTW - Low Voltage Power Pack...
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
478 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Rob Sinbad
Rob Sinbad
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
