Question about GE 24 in. GSD4020Z Built-in Dishwasher
Dishwasher leaks the dishwasher leaks on the floor. I think I need to replace a seal on the bottom of the door.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
n
Posted on Sep 29, 2010
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Leaking from motor
Water Inlet Valve
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Seal
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
Water leaks out on the floor from the front left of the machine, not every time though. what's the most likely place to check? intake hose? drain hose? door edge?
Hello there:
If your dishwasher leaks, check these: Main tub seal Note... If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. Lower rack Spray arm Spray arm support
Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Sep 26, 2010 | Maytag PDB3600A Built-in Dishwasher
My water will not dain in my diswasher and then leaks on to the floor. Is there a clog oris it something else
Hi
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | Magic Chef Dishwashers
Door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Dec 20, 2008 | KitchenAid KUDC25CH Dishwasher
Water seeping in dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jul 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking dishwasher
what sort of soap powder do you use
some soap powders foam a lot in machine causing dishwasher to leak through seals
also check that the machine is square that is the door is closing parallel with cabinet
do not use power balls in machine just standard dishwasher detergent and separate rinse aid
Feb 02, 2008 | Dishwashers
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
GE 24 in. GSD4020Z Built-in Dishwasher Logo
144 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
