SOURCE: 2002 Holden Astra 'Blaupunkt - CD player' MANUALS on the net?
This is a link to Blaupunkt for manuals, I don't see your paticular "model" though. See if you can locate it.
http://www.blaupunkt.com/us/downloads_1.asp
SOURCE: Please tell me if San
According to my database the SAN REMO CD32 (model number 7 641 160 310 ) is NON CODED
SOURCE: After 5 years with no
Check the contacts on the back of the display unit and on the front of the radio with the control panel removed...they should be clean looking...try to use an eraser from a pencil to clean the contacts...if this doesn't work...you may have cold solder joints inside the unit due to vibration and the heating/cooling cycles. If you know how to solder, you can check the solder joints to see if they may be bad...a cold solder joint looks like it has cracks in it. Where as a good solder joint should be clean and shiny with no cracks...make sure to use ROSIN CORE solder as this is the only type used for electronics...ACID core solder will render the unit totally useless...
Testimonial: "Thanks a million! "
SOURCE: i bought a blaupunkt san remo car cd-reciever on
Me too From Ebay can anyone help get these please?
