Question about Acer V223Wab Widescreen Lcd Monitor Blk
My monitor stops responding if i leave it alone for a while, if it's still on it freezes and if it went to standby it doesn't sense my computer. in both cases i have to restart my computer. Acer LCD monitor V223W on NVIDIA GeForce 9800 GT graphics card
Nic61
  • 1073 Answers
SOURCE: Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Posted on Dec 11, 2008
  • 7 Answers
SOURCE: Acer V223w monitor
Hello Cricket,
Sound/Speakers that are built into monitors, typically are pretty poor. I suggest purchasing some speaker from your local electronics store, or www.newegg.com. (New Egg has very good deals on computers and accessories, like speakers.) Here is a link to New Egg's speaker section. http://www.newegg.com/Store/SubCategory.aspx?SubCategory=60&name=Speakers
On the back of your computer, you will see little holes (3.5mm). They are usually color coded, Green is the typical speaker output jack/hole/port. When you buy your speakers, you will plug the cable with Green Head Plug (3.5mm) that is attached to your speakers, into this Green Jack. Turn them on, and you should have audio! Now, if the volume seems weak, you can double click the speaker at the bottom right of your Start Bar in windows. It looks like a little silver circle. This is your volume control There are multiple slide bars to adjust your audio.
Good Luck!
Posted on Dec 12, 2008
SOURCE: acer x 223w monitor and what video card
I have not answered the question about this problem, however someone else told me that I would have to change my graphics card to take full advantage of the features of the X223W monitor. But they did not know what I had to change it to.
Posted on Jan 18, 2009
  • 28 Answers
SOURCE: Is the T690 compatible with an Nvidia Geforce 8600
Yes, it appears the PC has a PCI-e graphics slot.
http://www3.shopping.com/xPF-Acer-Pentium-D-820-1GB-250GB-VHP
And it does not need an extra power cord in it so you should be fine with that card.
Posted on Apr 07, 2009
asnowman
  • 788 Answers
SOURCE: Driver
Here is a link to the driver you need.
http://support.acer-euro.com/drivers/monitor/v223w.html
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
Posted on May 12, 2009
HTC Wildfire Sense not responding
I have a few questions hopefully i can help if you are still having this problem. What version of Android are you running? Are you running a task manager app if so uninstall it? Try wiping the data in HTC Sense by going ini your phones settings then go to apps then select the all tab. Go down the list until you see HTC Sense. Hit Force Stop and then clear data. Hopefully this helps. Another recommendation is an alternative launcher from the Play Store such as ADW EX or Apex Launcher. Hopefully this helps. The old HTC Sense is a resource hog and replacing the launcher will improve performance. An even bigger step would be to root the device and remove sense all together. Let me know if you need help with this.
Nov 29, 2012 | HTC Wildfire Cell Phone
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
My computer frequently stops responding, specially when i minimize windows. My screen usually leaves annoying images. I think it freezes that way. I've checked the device manager, my windows...
How much memory does your computer have? Alot of times when the temporary memory gets full everything will slow down and will cause applications to stop responding.
It can also be your hardrive is too full. The more space you use on your hardrive the slower it will go and if you fill it too full it will also make programs stop responding.
Sep 15, 2011 | Microsoft Windows XP Home Edition
I have a SyncMaster 2232BW monitor hooked to my pc, the blue power button comes on when power on, my computer POST appears for about a second then vanishes leaving only bright lights on display, none of...
Seems that you may have the wrong type of video selection theres a button for auto sensing the type of connection. if your video cable is blue then you have an analog connection, white video cable is a digital connection you just need to ensure that the monitor is set to the proper selection.
Sep 05, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
My monitor suddenly went black when I awoke it from standby and it only states "video input 1 D - SUB NO SIGNAL" each time I turn the moniitor off an on again. I checked all connectivity to the...
My suggestion is going to be if you have another computer that you can hook up to the monitor and see if it works for it then the problem would be not the monitor but your computer. As it is telling you that it is not recieving a signal. If it still doesn't work then it will be something wrong with the monitor or the cable connecting it.
Jun 20, 2011 | NEC MultiSync 1770NX 17" LCD Monitor
After the computer is left alone for awhile is will start flashing Acer on the screen and the power button will change colors from blue to an orange looking color. I have tried moving the mouse and...
The monitor is entering "standby" mode.
In Windows, click Start.
Click Control Panel.
Click Power Options.
Change the number of minutes before entering Standby Mode.
May 14, 2011 | Acer X193W LCD Monitor
My ipod A1320 freezed and would not respond to anything.
Hi. My ipod nano (a1320) just stopped displaying anything. doesn't seem to charge or respond to plugging into computer.
Any idea what i can do?
Nov 05, 2010 | Apple iPod nano 2nd Generation MP3 Player
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
It doesn.t respond I can,t accesse t the menu and Ican't make photos
Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 11, 2009 | Panasonic Lumix DMC-LZ1 Digital Camera
Screen will not power on
most generaly capacitors on main power supply board
Dec 15, 2008 | Computers & Internet
Acer V223Wab Widescreen Lcd Monitor Blk Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
