Question about Sony Playstation 3 (PS3) Console
My ps3 has stopped connecting to the internet, checked internet and it is working, how do I sort it?
    President:
  • 1,139 Answers
I had the same problem. What you can try is go to the recovery menu. Turn the PS3 onto standy (red light on). Press and hold the power button. It will beep as soon as you hold it, keep pressing it until it beeps again and then once more 5 seconds later. The system will switch off. Press and hold the power button again, 1 beep straight away, then another 5 seconds later then 2 quick beeps, let go of the power button. It will now boot into the recovery menu. Select restore file system. It will restore and then reset. Hopefully this will solve it for you.
Posted on Jul 31, 2010
Getting error code 8071053d tried rebootin ps3 and internet not working still wont let me play online
The error code indicates that the PS3 is unable to contact the Playstation Network Servers. This may be caused by the PSN (Playstation Network) being under excessive load (often a result of new, significant DLC being released) or a problem with your router or ISP (Internet Service Provider).
  • On your Playstation 3, go to the Settings menu, scroll down to the bottom and select Network Settings, then select Internet Connection Test. If you do not see success for Obtaining IP Address and Internet Connection, then there is a problem with the networking between your PS3 and the internet.
If you both of these connections prove successful, but you are still not able to sign in to the PSN, try:
  • Contact your ISP and see if they have some sort of outage in your area or are somehow hindering your connection to the Playstation Network.
Mar 13, 2011 | Sony Playstation 3 (PS3) Console
I have a belkin F5D8236-4 v2 and wish to change nat type from 2 to 3 so that i can play cod online. as the playstation is set to nat 3 i am rather new at all this. i have tried all sorts of forums etc for...
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Dec 11, 2010 | Belkin (F5D7230-4) Router (587009)
My dualshock 3 controller wont connect to my ps3
i just got my new sony dualshock 3 controller (Japanese white version, i dont know if that matters) and when i try to connerct it without a USB the 4 lights will just flash and evenually just stop as if there was no ps3 there. If i connect it with a USB it will look as if it has connected, the ps3 will think it has but there is no input form the controller and instead of the first light going on the first and the second will go on. if anyone can give me any sort of help that would be great.
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Trouble connecting to the internet w/PS3 using an cricket aircard
the best thing for you to do is get a cable and attach it to the internet port. the cricket aircards have a tendency to fail or stop working entirely
Aug 18, 2009 | Sony Playstation 3 (PS3) Console
1st 80Gb ps3 model gets hot really fast..
Make sure that your not placing your system on any sort of carpet or rug this will cause the system to overheat. Also check the fan on the back of the system and make sure that the fan is clean and not full of dust and other sorts of stuff. If this does not stop then i would go buy a cooling fan for it just to make sure it dont fry the motherboard!!
Jan 31, 2009 | Sony Playstation 3 (PS3) Console
No internet connection
Check your network settings and make sure your system is set to wired connection not wireless
Nov 15, 2008 | Sony Playstation 3 (PS3) Console
My problem with internet
Hi there Case,
it seems like your PS3's Motherboard could be the problem with you not being able to connect, either their are faulty connections or damaged wires which connect the Ethernet port directly to the motherboard itself, if your PS3 is still within its warranty i wouldnt advise attempting a DIY remedy to the problem, instead i would suggest calling sony customer support and asking for advice to see if they can sort out a repair or replacement of your system
Hope this helps !?
Oct 28, 2008 | Sony Playstation 3 (PS3) Console
Ip address timing out
ur signal to low or u either have to type ur ip adress
Jun 10, 2008 | Sony Playstation 3 (PS3) Console
PS3 Error Code 80710102
The 80710102 problem is caused by a DNS error, which basically means that your PS3 is trying to navigate the Internet without knowing where it needs to go.
If you follow the link below I have written an in-depth (and free) article about how to fix PS3 DNS errors and get rid of the 80710102 code on your console.
Mar 30, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
141 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
