Question about Maytag Kitchen Ranges
Maytag electric kitchen range error message F1
  • 6,784 Answers
HI. This code is in reference to a failed touch pad. Now; If your unit is equipped with an all in one assembly(touch pad and main control board are combined as one assembly), This will require you to replace the entire main board assembly. In order to isolate the problem if your unit is equipped with a touch pad that is not attached to the main board, follow the procedure below.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power running to the range has been disconnected, so please double check before continuing this procedure.
2. Now; Gain access to the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was after you have successfully disconnected the touch pad ribbon.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
  • NOTE_ Again; This test is not needed if your unit is equipped with a ERC that has an incorporated touch pad. You will only need to replace the entire ERC assembly in this case.
Posted on Jul 31, 2010
  • Michael Masters
    Michael Masters Jul 31, 2010
    If you would like to be directed to the proper replacement part, please, post the entire model number that is associated with the affected unit. That model ID is very important when searching for parts. Please post this much need information if you seek the correct replacement part needed.
F1-4 Error message displayed
Hi jwill343,
The F1:-4 error code means "Runaway Clean Lower oven".`You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Mar 04, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Maytag electric range shows F1 error message and beeps every hour or so. we've checked the fuses and they seem okay.
F1 code means a defective touchpad or membrane, usually the touch pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: Disconnect the power to the range
Gain access to the back of the ERC (clock)
Unplug the touchpad ribbon connector from the clock
Make sure everything is clear & will not short out when the power is turned back on to the range. Replace any covers removed to gain access to the ERC.
Turn the power back on to the range
Watch for the F1 and listen for the beepIf you get the F1 and beep, replace the ERC (clock)
If after approx. 60 min. you do not get the F1 fault, replace the touch pad. Note: some ranges incorporate the touchpad and the clock as one part so F1 means a bad clock control.
Nov 12, 2009 | Maytag MER5770 Electric Kitchen Range
. THE MESSAGE APPEARED WHILE I WAS CLEANING THE
F1:-4 Runaway Clean Lower oven Check oven temperature sensor, replace if necessary
Nov 09, 2009 | Maytag Gemini 30" Self-Cleaning...
We have a beeping sound and an error message F1-8
The code F1-8 means you have a shorted keypad. Check to see if steam or other moisture is getting into the clock assembly. Replace the keypad if necessary.
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Electric range F1-1 persistant fault code
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
#$%^Y
Jun 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini mer6770aw
May 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag electric range shows F1 error message and beeps what does this mean? and now it permanently shows this message and not thee closk
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 03, 2008 | Maytag MER5770 Electric Kitchen Range
F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Jun 05, 2007 | Maytag MER5875QA Electric Kitchen Range
Kitchen Ranges Logo
18 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
