Question about Mitsubishi WS-65869 65" Rear Projection Television
We had a power outage, the tv was off. After power was restored the green timer light was blinking and tv will not power on, I have tried to reset it but the light starts again, What now? It is a Mitsubishi WS-65869 65in rear projection
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It means that the microprocessors inside the unit are unable to communicate with each other. Usually this TV has 1000uF/16 capacitors in the DM MODULE (which is one of the two microprocessors). As these capacitors are too small for the load they get they usually fail after about 3-5 years or due to voltage fluctuations. To resolve this issue these capacitors should be replaced with 1000uF/25 volt or 1000uF/35 volt capacitors, so that they can handle any voltage spikes that will occur. To do the repair you’ll need to take the back of the TV apart in order to remove the faulty DM module and need to desolder the old capacitors and solder new ones. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
  • leroybryant Jul 31, 2010
    hello I fixed this issue. I just pushed the reset button which there are two of at the same time and then hit the power button before the light came back on the tv is working great,no need for expensive replacement parts
  • Rylee Smith
    Rylee Smith Jul 31, 2010
    Thats great, Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Green light on front of TV keeps blinking after power outage. I have tried powering back off and on and resetting the tv. Nothing works
Thats caused by weak DM capacitors when power is lost even for a minute the caps drain and then cannot charge again when power is restored so the led will blink non stop. The Repair kit called the WS48511 - WS65511 DM repair kit should solve the issue. The kit contains the caps and the cd with repair instructions. The kits available from www.tvrepairworld.com
Aug 02, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55859 power on problems - green light blinking
have you tried holding menu button down for ten seconds... sometimes the front panel gets locked
Apr 07, 2008 | Mitsubishi WS-55859 55" Rear Projection...
There was a power outage in my zipcode; and when the power came back on, the timer light on my tv was blinking and will not stop. This is not allowing me to turn on my tv.
Thats a very common problem caused by bad DM capacitors. The caps discharge during the power loss and then cannot recharge when the power is restored whcih causes the steady blinking green led. You can get the DM repair kit for your model at www.tvrepairworld.com which does include the upgraded caps and the CD with instructions.
May 06, 2011 | Mitsubishi WS-65809 65" Rear Projection...
After a power outage my wd62525 won't restart.......the green timer light has been blinking for more than 24 hours HELP!! (I did try to reset, same blinking)
There is chance that the power outage might have damaged the power supply. It does happen, it's most common with storms. I recommend that you go to a shop and get that board checked
Dec 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Blinking "Timer" light for WD-62725
If this is a DLP, you may have problems on the FMT/DM boards in the sealed electrical chassis.
That's a big problem, because Mits doesn't make the DM/FMT boards available anymore. They are only available for rebuild from Mitsubishi and other qualified places.
There is a chance that there are some vented capacitors on the DM and FMT boards you might be able to replace, but it's for someone really comfortable with completely disassembling a set, soldering in 8 new caps and rebuilding the chassis.
Rebuilds will run you $400-$500 in rebuild costs and an additional $200-$400 in labor, depending on the joint.
Jul 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
